MF 135 Power steering issues
/ MF 135 Power steering issues #1
jticknor
Travelers Rest, SC
I have an orchard MF 135 and a MF 50C Backhoe
Ok, I have a 74 (or 73?) MF 135 orchard. Diesel. A couple weeks ago I was tilling my garden and busted a power steering line on the left side from the piston to one of the fittings under the steering column. Had my hydraulics shop make me a new hose (actually just went ahead and replaced both on that side). Bled the system out, I used a pureguard "premium hydraulic fluid j20c and quatrol approved" that a local MF dealer sold me that I was of the understanding would be used for power steering.
Here is a link to the fluid: https://omnisp.sharepoint.com/sites...eguard/Technical Data Sheets/PDSs&p=true&ga=1
Cranked it up, used it to till my garden. Probably was on it an hour or so. No real problems, other than the steering being maybe a little stiffer than it used to. Got on it yesterday to use my box blade and now the steering is much more difficult. Basically when I turn my wheel smoothly, evenly, i get short jerky responses from the pistons, as in I move the steering wheel fairly fluidly from 12 to 3 oclock and i got no movement from the pistons, then an inch or so jerk, no movement then an inch or so jerk, if that makes any sense? Bled everything again, topped off the reservoir, no difference. Did i do something wrong or is this one of those situations where you fix one thing and something else breaks because of it? I'll try to add a video to see if that helps.
/ MF 135 Power steering issues #2
Hi,
Does the power assistance fail at the same steering wheel positions each time you cycle through a fully left to fully right turn?
Can you view the fluid reservoir when the motor is running? If so, are there bubbles or foaming in the fluid?
/ MF 135 Power steering issues #3
It looks to me like (from the video) that you still have air bubbles in the fluid. A signif question is did you have any of these symptoms before the hose incident? If not, it almost has to be an air in the system issue in spite of you having bled it twice.
Hi,
It does not seem to be exactly the same spots but it’s kind of hard to tell. Seems to have more to do with how far I turn the steering wheel at a time? Like I can turn it may be 5 to 6 inches and then it’ll happen another 5 to 6 inches and then we’ll do it again. If I open the reservoir while the motor is running there is an awful lot of fluid tries to come out. I’ll try again here in a few. It does seem kind of foamy. But also seems odd I didn’t have those problems so much for a few hours of use afterwards.
I did not have those problems before I switched the hose. Before that it turned nice and smooth. But I also didn’t really have that problem so much for a couple hours afterwards.? What would I need to do to make sure I bleed the system all the way?
/ MF 135 Power steering issues #6
That is VERY strange. I'd be purely guessing at this point. If a hose or rubber part were "ballooning" that might explain it but those things burst instead of balloon. Since it was not happening before the hose incident it just about has to be air pockets somewhere in the circuit. I can think of nothing besides more extensive bleeding which it seems you already did. There's no mechanical anchor point loose or failed to be reconnected is there?
/ MF 135 Power steering issues #7
Hi,
To check if the oil is foamy, try looking at the appearance after it has sat for a few hours compared to immediately after it's been running.
If it's foamy, read on.
I was also in this position of thinking "perhaps I haven't bled it enough". But these systems are invariably self bleeding by going full L to R 2-3 times. The pressures of course are high, so there's really no way for air hide. Continue to think it through, but if the oil is foaming, I am sure you will reach the conclusion that new air is being drawn into the system and that it's not just some air trapped somewhere.
I forgot to mention that when I had this issue the steering would also be power assisted intermittently after a start up (after several hours stationary). It would assist for around 5 seconds, then fail, and returning the wheel in the reverse direction there would be a burst of assistance before it failed. I think this is the unfoamed oil in the lines providing proper pressure, before foamed oil gets into the system.
When I resolved the inwards air leak, my system bled with two full turns each way and has worked fine since.
My suggestion is look hard at the pump intake side of the system and if the lines seem good, then the shaft seal inside the power steering pump is the issue.
Why would this arise after repair on a line? No idea, or dumb luck. My issue arose 6 hours after a filter and fluid change for the power steering, and my pump is remote to the reservoir so there's no mechanical reason. Was mine coincidence or due to the new fluid? No idea. Working fine on the same fluid now.
/ MF 135 Power steering issues #8
That is a great post by FordnMassey. Makes all kinds of sense.
Hi,
If I'm getting air in somewhere, besides the seal, shouldn't I be seeing fluid finding its way out? I didn't mess with much in the system when I replaced those two lines, and those two lines don't show any signs of leaking. I did see mention somewhere that i could have gotten the lines crossed, but seems if that was the case the two sides would be fighting eachother and not moving much at all? I'll look at the foaminess situation again tomorrow but it does seem foamy. Wondering if the different pressure changes and whatever else involve could have blown that seal....although it did seem equally foamy when i orignally bled the lines and then used the machine for an hour or so with no real issues...
/ MF 135 Power steering issues #10
No, a small air leak on the inlet side of your pump would always be under suction (negative pressure) when running and no pressure when not running so you'd probably not see any fluid leakage. Besides, the air leaks, if they are there, are probably very tiny and not easy to find or see. Could have been that way for a while and just got worse wiggling things around during the incident.
/ MF 135 Power steering issues #11
On my MF245 when topping off my power steering fluid, I put the front on blocks and turn the wheels back and forth a number of times with the cap off to get all the bubbles out. When in one direction or the other (can't recall which) the system holds more fluid. So I top it off on the higher fluid direction and then put the cap on. I don't know if your MF135 is set up the same.
This link says to top off with wheels centered.
/ MF 135 Power steering issues #12
Jwr has nailed it. The air leaks inward on the suction side. For a seal to fail in this way is very different from a seal leaking a fluid out, so it's pretty easy event for there to be no oil leaking out while air gets in.
Additionally, the seal that fails is on the input drive shaft of the power steering pump. The drive for the pump is likely a gear on the pump shaft that meshes with a gear inside your engine. This set up usually allows oil leaks from the seal to go to the engine sump where you can't see it.
The key idea here is air leaking inward due on the suction side of the pump. We almost always deal with fluid leaking out, so it's a bit of a shift in thinking to get a handle on.
If you have foaming oil that keeps recurring, you have air leaking inward on the suction side.
Mine was a Ford 3000, 1967, external cylinder, remote reservoir type power steering. May have been sucking air for a while, and finally got bad enough to overfill the reservoir. I took the bonnet off and the jet if foamed oil spraying was something to see! It only becomes a noticeable problem when the oil can't lose the bubbles faster than they're created. So may have been there for a while before I knew about it.
My pump was rebuilt in around 4 hours, half being cleanup and removal. It was not complicated..... I'm not a mechanic and I did it easily.
Stupid question: the service manual says to keep bleed it until you can leave the plug out of the reservoir and the fluid stays calm. Even when turning the steering wheel and while it's running? When I try that the fluid goes everywhere....
Like which seal are you talking here? Thinking I may just be getting the rebuild kit that comes with all of the seals. You referring to that seal no 9 there on the shaft where its heads into the engine?
I just spent probably 30 minutes with it cranked and the plug out of it turning the steering wheel back-and-forth. Every time I turn all the way to one side and then start to turn back the other I get air coming out. Both directions. And then when I stop and turn it off I get bubbling for a while afterwards. Like pretty decent sized bubbles gurgling out. Seems that would mean either a pretty serious leak or somewhere there was a lot of air in the system? Wondering if maybe the pressures involved in the system busted an already compromised seal? But if it was all going into the engine shouldn’t I see that in the engine oil? That does seem to have made it better. But it’s definitely still not right….
/ MF 135 Power steering issues #16
I never considered the design on my MF245 to be ideal but it works good enough.
/ MF 135 Power steering issues #17
Hi,
Yes, if no9 is a seal, that's what I reckon is the trouble.
Regards the leaking into your sump, it's unlikely that oil gets out, but if it did you won't see it. I'm suggesting this is a leak allowing air in. That's why you can't purge the system no matter how much you try.
I would recommend a full seal kit. If one seal has failed, other seals/O rings will fail soon.
Thanks. I’ll give that a try and see what happens.
I've rebuilt the pump. A question. Theres a relief valve that I had to (or at least thought I had to) remove in order to get it apart and replace the seal. Seal went in ok, old seal did seem pretty worn out.
This relief valve, the service manual says to adjust it to 1500 psi. Any thoughts on how to make sure it's right? The only way I know is put the pump on, crank it up with a gauge hooked up between the pressure line and the pump and if its not right take the whole thing apart and try again? Wish I'd marked where the damn thing was at before i took it apart. Rookie move....
/ MF 135 Power steering issues #20
Hi,
Yep, that's unfortunate. I don't know the set up of the relief valve as I avoided dealing with it on mine. So I can't offer a better idea than yours. Wait to see if anyone else has a good idea.
2022 EZ-GO ELITE...
Onan HomeSite Power 6500 Generator (A66408)
Onan HomeSite...
Welcome to the Ranch (A64557)
Welcome to the...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
