MF 135 Gas won't start
   / MF 135 Gas won't start #1
GDebt
Sunbury, Ohio
JD 4410
I have a project. We have a 135 that sat for several years we are trying to get running again. It had been used daily up til the time the owner got sick. We have drained and refilled the gas tank cleaned out the sediment bowl. Rebuilt the carb. Replaced all ignition wires, cap rotor, points and plugs, had to replace coil and ignition switch. We now have spark and clean fuel. Tractor rolls fine you can smell gas but no joy.
What are we missing?
   / MF 135 Gas won't start #2
Spark and fuel should run, but you already know that. Could you possibly have the sparkplug wires mixed up and on the wrong cylinders? On mine with perkins engine the wire on distributer @ 11 oclock position goes to #1 cyl, 3 oclock goes to #3 cyl, and wire @ 7 oclock goes to number 2 cyl.
You also may try advancing or retarding the timing a little by rotating the distributer back and forth.
   / MF 135 Gas won't start #3
Are you sure you're getting fuel and spark? Check at the plug for a good spark and cylinders for fuel with a plug removed. Also, and don't be insulted because I've forgotten it myself, is the fuel shut-off open or closed.
   / MF 135 Gas won't start #4
Make sure the initial timing is correct and the firing order is correct.
   / MF 135 Gas won't start #5
Crossed plug wires, timing is out of adjustment. Sticking carb float valve. Leaks in the carb seals. Contaminated, misadjusted and/or damaged jets.
Good luck.
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2013 KENWORTH T800(INOPERABLE) (A53843)
2013 KENWORTH...
2012 Dutchmen Voltage V3950 42FT 5th Wheel Tri-Axle Toy Hauler Travel Trailer (A51694)
2012 Dutchmen...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
