MF 135 diesel does not restart after choking off
   / MF 135 diesel does not restart after choking off
OK. Will do.
It does seem to regulate the rpm correctly. Thanks again!
   / MF 135 diesel does not restart after choking off #12
The problem is to much unburned fuel in the cylinder. Not enough oxygen. If you let it sit for a while it would start up. starting fluid is so flammable that it ignites and sucks lots of oxygen in to burn thus compression takes over for the diesel. Yes when I first started reading it I was like, well dont start a load up while idling. We've all done things like that though so just laugh at yourself. I wouldnt use ether either. LOL If you do just the smallest amount will do. I've seen some people use ether that I think they used it before spraying it in the tractor. Motor knockin retards.
Toddol, thanks!
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
International 5088 2wd Cab Tractor (A52128)
International 5088...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
