MF 135 diesel does not restart after choking off
   / MF 135 diesel does not restart after choking off
OK. Will do.
It does seem to regulate the rpm correctly. Thanks again!
   / MF 135 diesel does not restart after choking off #12
The problem is to much unburned fuel in the cylinder. Not enough oxygen. If you let it sit for a while it would start up. starting fluid is so flammable that it ignites and sucks lots of oxygen in to burn thus compression takes over for the diesel. Yes when I first started reading it I was like, well dont start a load up while idling. We've all done things like that though so just laugh at yourself. I wouldnt use ether either. LOL If you do just the smallest amount will do. I've seen some people use ether that I think they used it before spraying it in the tractor. Motor knockin retards.
Toddol, thanks!
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
