MF 133
/ MF 133 #1
LesterTPE
MF133
Hi all. I have purchased a MF 133 french model with dry sealed disk brakes. I am having difficulty identifying the parts for the axles etc. Would anybody have a parts book
or be able to help me with this.. Thanks
/ MF 133 #2
Do you have a picture of the rear end? The normal agricultural 133 should have very much in common with the 135 but has a slightly smaller displacement 144 vs 152.on the 135.
/ MF 133
This is the hub with adjuster for the brakes. I will get more photos shortly
/ MF 133 #6
No parts number on them?
/ MF 133
No OEM Part numbers . Outer hub seal is 897198
Bearing is 395A & 394 A whish i have found on internet
Inner dust seal as pictured has no numbers and is 121 mm OD
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
