MF 1250 4WD
   / MF 1250 4WD #1
toa5150medic
Blythe, CA
1995 Massey Ferguson 1250
I noticed the 4WD was not working on my 1995 MF1250. Upon inspecting underneath, I noticed the drive shaft from the transmission had come disconnected from the shaft going into the front differential. There appears to be a connector that slides forward and holds the two shafts together. I cannont get that piece to slide forward. And if it does what keeps it from slipping off again? Sorry about my lack of proper terminology, but I am new to the world of tractors. Thanks for any help.
   / MF 1250 4WD #2
I've seen this before, their is usually a split ring, and a collar that retains this item in position, by the looks of what your describing, you sheared a pin, need a picture to make sure and also make sure you have all the part numbers in this area, these parts are not expensive, however, you do have to be exact.
Kenneth J Kinney
2014 Mack CXU 613 Semi (A50514)
2014 Mack CXU 613...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
CAT Skid Steer (A50322)
CAT Skid Steer...
