MF 1230 Front Axle Fluid capacity
/ MF 1230 Front Axle Fluid capacity #1
mustang5
I have a MF 1230 4wd tractor. The front axle is leaking fluid. When filling this front axle with fluid, should it be filled all the way to the top? or should it only be filled to a certain level? I purched this used with no owners manual or service manual. Any input would be helpful! Is it safe to use UTF in this 4wd front axle? THANKS, Mark
/ MF 1230 Front Axle Fluid capacity #2
I am not sure about the fill level, but I use UDT for my hydro tranny and front axel so it would be same for you.
Thanks for the reply. I am going to use it and get it in the shop to fix the leaks. Thanks again.
