MF 1100 Tractor
   / MF 1100 Tractor #1
Pedrojoe
Beaumont, Texas
MF 1100
My Massey Ferguson 1100 tractor has no hydraulics. All at once no signs the hydraulics quit. Changed and cleaned both filters on the hydraulics. Took the charge pump off. Charge pump has all parts a moving. No keys are sheared off. Just puzzled.
   / MF 1100 Tractor #2
The is a little tiny shaft coupler inside the transmission that has more than likely sheard off the splines. My MF 1155 did this 3 time before i got rid of it. It connects the front shaft from the flywheel to the rear shaft that turns the pto and charge pump. All 3 time i had to replace the coupler and rear shaft. Just the parts were expensive but getting to it was the nightmare. The transmission has to split right in the middle. Call the mf dealer or abiline machine for help diagnosing the problem to be sure. If it is what i think it is. Abiline machine has the parts much cheaper now. Shaft part # am503433m1
Coupler # am516006m3
Get you a s I&T shop manual from abiline machine too. They are only 31 dollars
   / MF 1100 Tractor
Also my PTO clutch moves freely in and out of gear
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2008 CATERPILLAR 325DL Long Reach (A52384)
2008 CATERPILLAR...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
