MF 1040 Hydraulics/Loader Issue
/ MF 1040 Hydraulics/Loader Issue #1
davidshobson
Nashville, TN
Massey Ferguson 1040
I have a 1985 MF 1040 with loader. I replaced four lines on the loader after blowing one. I also replaced the hydraulic filter. Now the loader will only go up and the curl action wont work at all. I cracked several joints in the system looking for air, but found only oil. I replaced the loader valve a year ago and had a similar issue, but it eventually worked out. I can't work this out, because I can't exercise the system as it only goes up.
Any ideas?
Thanks in advance
/ MF 1040 Hydraulics/Loader Issue #2
Did you replace all line at one or did you replace them one at a time?
I guess all at one and you crossed a line.
I would disconnect or crack each line and work your valve to check if the fluid flows or leaks where it should.
/ MF 1040 Hydraulics/Loader Issue #3
Using a loader valve with PB, you should have 7 hoses.
IN hose
OUT/TANK hose
PB OUT
4 cyl hoses
Pump flow goes to IN port.
PB hose goes downstream to the next valve.
Cyl hose conect to the appropriate port on the cyl.
OUT port goes to the OUT/RETURN line.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
1024 (A63111)
1024 (A63111)
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61572)
1984 Charles...
