Metric Hydraulic Fittings
/ Metric Hydraulic Fittings #1
FredM AZ
Arizona
Jinma 304
Have found many field repair kits for SAE but I need one for 6mm ,etric inside diametrer hose. Searched internet to no avail. Anybiduy have any suggestions?
Thank you in advance
/ Metric Hydraulic Fittings #2
Try discount hydraulic hoses. They may have what you need. Other option may be a hydraulic hose shop in your area.
/ Metric Hydraulic Fittings #3
Is this a high pressure or low pressure hose?
Often people replace hoses when a leak occurs.
For fittings, if you need for a 6mm ID hose, you can probably get away with a barb designed for a 1/4" ID hose.
The last time I tried to get metric hoses made, I went to to the local CAT store, and they directed to a hydraulic only place. Neither liked my hoses and fittings. :(
It turns out my leaking line was a low pressure line. I ended up grinding the fittings off of the hose and put the fittings into some fuel line hose, slightly undersized with screw type hose clamps.
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
2015 KOMATSU D61PX-23 CRAWLER DOZER (A60429)
2015 KOMATSU...
(38) 8" - 11'L X 20" - 34" FLOOR TRUSSES (A60432)
(38) 8" - 11'L X...
2012 FORD F-150 XL EXTENDED CAB TRUCK (A60430)
2012 FORD F-150 XL...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
