Method for Heating Cast Iron for Welding
/ Method for Heating Cast Iron for Welding #1
zzvyb6
Super Member
michigan
jd 1070
I have an old farm windmill to repair which has been damaged when they toppled it. There is a large piece broken out of the cast iron crankcase. It is a "clean" break (meaning just one very large piece is broken out. No small or lost pieces. Unfortunately, this piece has one of the standoffs on it used to hinge the tailbone (so there is some load on it even when its just sitting still.
I'm interested in welding it back together. I've done cast iron repair before with AC and nickel rod (some cast gears used on farm machinery that were in quite a few small pieces). For those jobs, I just clamped the gear pieces together and hit it with the nickel: no preheating, just some grinding to removed rusted metal and to create a groove in the parent metal to receive the nickel.
I saw an add on Craigslist for a gas fired oven specially used to preheat cast iron for welding and it occurred to me that I could use my barbeque grill to do the same job. Its a 4 burner unit, seldon used, and smells a lot like ribeye. What do you think of this idea? What temperature would be recommended to achieve with the cast iron before welding it? I'd do the same pre-treatments as with the gears: grind edges and use nickel. I suppose my other option could be to use my gas wrench with a rose bud to preheat it.
Any thoughts or advice? I've thought of a mechanical fix as well. I could use bolted angle iron pieces to tie it together and use the weldment just to seal the oil filled crankcase. I'd just don't want to make it brittle and disintegrate. Metal quality on these old parts is very good. It may even be cast steel.
/ Method for Heating Cast Iron for Welding #2
Pre heat means about 500 degrees.
I repaired a broken exhaust manifold on a J-D crawler. It was a little three cylinder job.
Jigged the parts on to a length of angle iron. put the works in the BBQ with the break upper most and shut the cover. Waited about 1/2 an hour.
Brazed the pieces right there in the grill.
That was about 15 years ago......it's still going from what I see.
I don't weld iron .... brass is so strong. I hear they make bronze out of it ;-]
/ Method for Heating Cast Iron for Welding #3
this is the way i would weld it .cast steel 1/8 7018.cast iron certanium 689 .i would v it out ,then weld about an inch peen it then let it cool .repeat til finished.
/ Method for Heating Cast Iron for Welding #4
It is all about the heat. I have used fires, special ovens, cooking ovens ( gotta have a good wife), cutting torch and time. I do prefer to braze cast instead of welding. Have fun!
/ Method for Heating Cast Iron for Welding #5
one thing i would add is to practice first. get an old cast iron frying pan and break it, then try welding it.
/ Method for Heating Cast Iron for Welding #6
Grill is a great pre heat tool. Also can get a Weed burner or big bertha to do the job. I doubt that it's cast steel but you need to find out. There is a grind test you can do and you look at the sparks to see if it's cast iron or not. Oppinions vary on the repair. I would heat it, Tack it and do small stich welds until completed. Work opposite ends and work toward the middle. Peen after each weld. The key here is not getting in a hurry. You can use a multitude of Nickel rods. If it's cast steel, You can use Stoody Versalloy or Super Missle Weld (312 Stainless ). If it were mine I would use a Spray Powder Torch set up but use what you have. Any of the above will work ok.
/ Method for Heating Cast Iron for Welding #7
Sounds like good advice. Take your time heating and cooling.:D
Make sure the better half doesn't put some sauce on it!:laughing:
I watched some videos on YouTube about welding and brazing cast iron. The 1" stiches followed by peening is recommened by the Lincoln Electric demo. I had a Red Bull moment after watching as he stated that the reason for the preheating was to control the contraction as the weld cools. If they all cool together, there is less chance of cracking. Originally I was thinking that the preheating was necessary for some kind of chemical reaction to take place but it's really just a controlled thermal change. In fact, they recommend using the grill during welding so that you can gradually cool down the item by reducing the flame over the course of a few hours when you are finished.
/ Method for Heating Cast Iron for Welding #9
Brazing it would probably be a better and stronger repair than welding. A BBQ grill works great to preheat. A kid's sandbox works great to slow the cooldown.
/ Method for Heating Cast Iron for Welding #10
if this is any good to you but i would do the same as all the other guys ..one said watch the sparks off a grinder ...need a little more then that . i know that is how you tell your metals but dont know what yet too look for .......anyways a licensed welder told me once to weld real cast take your torch get the soot black all over the piece you need to heat when the soot is on there heat till the soot burns off the heat to bur the soot is the same heat thats needed for welding ...never done it yet never had to but some day maybe
/ Method for Heating Cast Iron for Welding #11
and for giggles I glued this with my mig......:D. It lasted a very long..........15 minutes :laughing::laughing: No preheat just grind a "V" and go :laughing: I know it's the wrong tool but.....
/ Method for Heating Cast Iron for Welding #12
I like to lay the cast piece on top of the wood stove. Using a thermo heat gun the stove top is usually around 600deg with a fire going. Once the piece to be welded is the same temp as the stove top, I'' put on some coveralls to protect me from the heat and just weld the cast piece while laying on the stove. When I finish welding, I just leave the welded piece on top of the stove until the next morning. The stove will cool off as the fire dies down and the piece cools slowly at the same time. I have used brazing for the weld, but also nickel99 and nickle55.
I have an old antique fruit press that has a pretty large ushaped crack in it that I am going to try and repair. This piece was welded before I got it and had recracked the lenght of the weld. I have ground out the old weld and drilled a small hole at the end of the crack. On this piece, I dont want to use nickel or brass because of the difference in color of the weld material and the cast iorn. I will probably try welding with regular wire, which is what I think was used in the first attemp to weld the press. The difference will be I intend to pre/post heat the metal before and after welding. I have already attemped to use the Tig on a scrap piece, using another piece of cast as a filler but My tig skills aint that great. I dont know if it was my skills or something else, but the welded piece recracked, so I'll try the wire next. If that fails, it will be back to the nickel rods.
/ Method for Heating Cast Iron for Welding #13
If you have a MIG then get yourself some Royal 44 from Crown Alloys.
It's designed specifically for welding cast iron without the need for heating, etc. Just stick it in your machine and weld according to their instructions. Lots of guys get excellent results without a lot of hassle or expensive nickel rods.
2 lb spool is $70.00 but worth it when you consider how easy it makes the job.
Glenn.
/ Method for Heating Cast Iron for Welding #14
Heat it up and keep it at a minimum of 500 degrees, buy a "temp stick" (a crayon that melts at 500 degrees), weld it with 11018 or another high yield low hydrogen electrode.
To weld it run a bead on each side of the crack and then a third bead bridging the two, this seems to work best. an engineer ounce told me this helps to stop stress from the shrinking after the bead cools, but it does work
After you weld it make sure its hot again and wrap it in several layers of insulation (I use fiberglass batts you buy at the lumber yard) let it cool over a long period. When its done right the piece is still warm to the hand 24 hours later.
We use this method to repair cast steel bell cranks on large loaders and pieces that are cast on large yellow equipment, It works
/ Method for Heating Cast Iron for Welding #15
I used a bbq to preheat and slow cool after welding a cast iron stove door hinge. Here's my thread where I asked for help.
/ Method for Heating Cast Iron for Welding #16
BBQ if it fits, propane if it don't
JOHN DEERE 7320 TRACTOR (A62130)
JOHN DEERE 7320...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
Harlo HP6500 (A60462)
CATERPILLAR 259D3 SKID STEER (A62129)
CATERPILLAR 259D3...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
