Meteric fittings?
/ Meteric fittings? #1
wedge40
I have a backhoe that had all the hoses are metric. I would like to add about 2' of hose between the BH and the pto pump. I've managed to find a place that has metric to NTP fittings. But this will take 4 or 5 fittings per hose? Is there a pressure drop per fitting or shouldn't this be a problem?
Oh and if anybody knows of a place I can get a large selection of metric hydraulic fittings and hoses on the web let me know.
Wedge
/ Meteric fittings? #2
You don't want to and don't need to add that many fittings to get where you want to go. Why not just have your local hose shop make a 2' hose that will go from your pto pump to the existing hose?
As far as buying hose and fittings on the web goes, unless you want to use all field attachables (reusables) or you have a hose crimper in your garage, you're out of luck. I have over $50,000 in hose 3 machines, so I can tell you that they ain't cheap.
/ Meteric fittings?
Thats what I tried and so far I'm two for two. Neither shop had metric fittings.
But at least now I know what I need. I have M22x1.5 and M18x1.5. I was given the name a another place that "SHOULD" be able to help. But I'm going to call first and make sure they carry metric fittings. With all the foreign manufactures in the US today you'd think more shops would carry metric fittings.
Wedge
/ Meteric fittings? #4
Actually, those #'s they gave you don't mean much. You see, there is metric heavy, metric light, and metric light-light. For instance, your M22x1.5 could be a 15mm tube size on a -8 hose (metric light), or a 14mm tube size on a -6 hose (metric heavy). I would think that if this is coming off of a pump, that this would be a metric heavy. Higher flow/pressure is usually metric heavy, after valves and to a component could be light or heavy, and returns are usually light or light-light. No, I don't stutter.
Try here- Distributor Locator
Find a local distributor. Distributors deal directly with the factory and tend to have the lessor common products.
Is this a Jinma product? If so, you are so S.O.L.
/ Meteric fittings?
Hmm lets see we're talking about high pressure hydraulic hoses, I'm going to guess.. Metric heavy. It sound's like you're telling me that nobody in the US carries metric fittings. Considering the number of foreign products in the US today I have a hard time believing that this is the case.
Oh and the hoses are labeled 1/2" and 3/8"
Also if it was a Jinma (which it's not) why would this be such a big deal. Did Jinma start making their own "special" hydraulic fittings?
Wedge
/ Meteric fittings? #6
Hello Wedge,
Well, only some shops carry metric. Most places that sell hoses don't sell hoses as their main line of income. So, they usually carry a limited selection of hose and fittings. If you locate a distributor, they tend to have a much larger selection than a tractor shop or auto store. Just to give you a for instance, there are at least 8 other places to get a hose in this county. My hose and fitting stock is more than all of theirs combined. If you want the normal stuff, all the other auto stores and tractor shops have it. Anyone that wants anything that's not common knows they have to come to me. I actually stock more metric fittings than anyone else around here stocks JIC or pipe thread.
Jinma can be a different animal. Go over to the Jinma section and read back thru some of the older hose and fitting threads and you will see what I mean. They have a metric flat face o-ring fitting that I can't even get. So, Jinma may actually make their own fitting. John Deere has JD only stuff, as does Cat and Komatsu. Caterpillar actually has their own hose and fitting plant which was recently taken out by a tornado.
Look, I'm not trying to give you a hard time, I'm actually trying to help you find what you need. Find a distributor, show them the fittings, and you're done. Andy.
/ Meteric fittings?
Hello Wedge,
I do understand you're trying to help. I happen to have the metric flat face with and o-ring type fitting. I'm calling a place in Indy tomorrow that their sole business is hydraulic hoses and fittings. In a pinch I can make due with what I have, but I'm trying to extend the hoses to make it easier to hook up to the tractor. If it gets to be too big a PIA then at some point in the winter I'll convert the whole thing over to metric, with all new cylinders, hoses and valves.
I guess I should mosey on over the Jinma area and see if somebody figured out how to solve this there.
Wedge
/ Meteric fittings? #8
Wedge,
Have you tried your local Parker-Hannifin dealer/distibutor? I've had good luck finding metric fittings there. Their website is here.
/ Meteric fittings?
Inspector507 said:
Wedge,
I was referred to J&F distributing by the shop I visited Saturday. I'm going to call tomorrow and see if they can help.
Thanks for the info. I'm keeping my fingers crossed.
Wedge
/ Meteric fittings? #10
Those dimensions you gave are just the outside thread dimension and the thread pitch. As mentioned, they apply to a bunch of different type fitings.
The metric O Ring Face Seal or ORFS, at least for the Jinma's, has been a tough nut to crack domestically. In a few cases, some have welded together their own custom adapter fittings to get from the chinese hose fitting to a domestic cylinder/valve fitting, or vis versa. The right type metric adapter might also be able to be machined to accept the "O" ring, but you are pretty much on your own in both regards.
Good Luck.
/ Meteric fittings?
So what I'm hearing here is if you purchase a Jinma or any other Chinese product they can not be supported. Not even by the dealer who sells it to you?
Wedge
/ Meteric fittings? #12
Wedge
Are Jinma dealers are not equal.
I make and offer aftermarket replacement hydraulic hoses for the 200 series Jinma's, some for the 300 series Jinma, All the hoses for the China made ZL20 & ZL30 loader.
I gave up on the China backhoe.
Ronald
Ranch Hand Supply
/ Meteric fittings?
Well this has taught me one thing.
Buy AMERICAN. Guess I should have invested the extra 1k or 1.5k and gotten a taylorway or maybe even invested in a another Koyker product.
Wedge
/ Meteric fittings? #14
Don't give up so quickly. With the majority of Americans buying by price only, the Chinese will own this country in the near future. I'm sure they will bring fittings when they come.
/ Meteric fittings?
Oh I haven't given up.. By no means.. I have a glimer of hope because all the hoses are SAE hoses.. Unless the Chinese are stamping their products with english type measurements. I'm heading to Indy Friday morning to see what a Parker distributor can do for me. I figure if all else fails I can have them make a hose with a new banjo connection and a different female end.
Like I said earlier, if all else fails I'll pull all the chinese stuff out and replace with SAE.
But just in case - Now where did I put that Chinese to English dictionary.
Wedge
/ Meteric fittings? #16
Wedge,
Here are a couple place I use.
Malone Specialty inc.
Discount Hydraulic Hose
Tomkins Industrial
Look under either the Metric fittings or British, since some British is used on some foreign stuff.
I've had really good luck getting all I need for my Kama 554 and My wife's Jinma. Just give yourself enough time for them to order from their supplier if they don't have it in stock.
Hope that helps a little.
/ Meteric fittings? #17
I deal with all 3 above. None of them have metric flat face o-ring fittings. Parker doesn't have them, Weatherhead doesn't. I researched these a couple months ago from a thread over on the Chinese section. I even called some old veterans of the hose and fitting business and got the deer-in-the-headlights stare. I can honestly say that these fittings are the first and only time I struck out. I'm meeting with my Weatherhead rep tomorrow, I'll bring it up with him as there may be a market for these.
/ Meteric fittings? #18
If I read this correctly you have a hose with the proper fittings on both ends. You want a longer hose to facilitate hookup. ???
If so have the shop cut the present hose in the middle and put in fittings so that an extra piece of hose can be added for the extra length required.:D ??
/ Meteric fittings? #19
No self respecting shop will do this. It's a lawsuit waiting to happen. Some may do it on the same brand hose that they crimp, other than that, no way. Crimps are measured down to the thousandth of an inch and have a tolerance of +or- .005". Almost every hose has a different wall thickness and crimp diameter. I have seen lawsuits from this, it's a slam-dunk for the plaintiff. There is no defense. You may have a local shop that does it and many times it will work okay, but it is a disaster waiting to happen.
/ Meteric fittings?
I'm heading to Indy tomorrow to try my luck. Since my pump doesn't require the flat face but must be adapted to the BH, I'm guessing I can get the metric banjo fittings and fittings that will work directly on the pump. If that's the case I will have them make two new hoses with the extra length I need/want.
Oh and I ask at the last place I was at if he could splice the hose in the middle and he said no.
Remember these are SAE hoses, not some weird Chinese things.
I'm waiting on a dental appt this morning.. If I get ambitions I'll take some photos.
Wedge
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
Copper Eagle Weathervane (A65583)
Copper Eagle...
2012 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2012 CM TRAILER...
International 311 6ft. Pull Behind Mower (A65640)
International 311...
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
