Snowblower Meteor 3pt snowblowers..?
   / Meteor 3pt snowblowers..? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Anybody own or use one of these snowblowers? Pros and cons?
Thanks.
AKfish
   / Meteor 3pt snowblowers..? #2
I have a 60" wide unit and have been using it for the last year. We have had lots of snow and the blower has performed very well. It seems to be well designed and dependable.
rim
   / Meteor 3pt snowblowers..? #3
IMO...FWIW, my personal thoughts & experiences.....'Round these parts, the Meteor is considered to be a "budget" machine....if at all possible, I'd shop Pronovost or Blizzard....bar none (well, except Karl2's Super Blower but thats ni a different league) the Pronovost/Blizzard machines are the best, and IMO worth every penny more then the Meteor...Things I've seen with Meteors..
-Busted Gearboxes...The gearboxes they are are essentially "Minimum" to meet HP Specs rated..
-Unbalanced Fans
-Thinner Gauge Steel
-Not the best rotation setups around
-Optional Skid Shoes (My Blizzard came with em standard and so does the Pronovost)
I'm sure I'll get flamed for this post, but I'm telling you MY Personal preference. Go shop around...take a look at em in person and if you can get the brands side by side, you'll see what I mean. Quality & Workmanship on my Blizzard (and the Pronovost) are second to none.
   / Meteor 3pt snowblowers..? #4
I looked at a used Meteor. It seemed to be holding up well. I had issues with the salesman that killed that deal.
   / Meteor 3pt snowblowers..? #7
My 68" Meteor has been great. I've hit lots of things with it and broken several shear bolts and no troubles at all.
If I was purchasing again, would checkout the Provonost to see what the price difference was. If it is substantial, I don't think I'd hesitate to get a Meteor again for my homeowner type use.
I would definitely check into that gearbox thing thought particularly on the smaller ones.
   / Meteor 3pt snowblowers..? #8
I have an older 60" meteor I bought used it's about 8 years old broken shear bolts occasionally no other trouble's,but I've seen the post on the bad gear boxes. If you were looking for a walk behind check this out. possible a little heavy on gas but should throw snow. Gary
   / Meteor 3pt snowblowers..? #9
Thanks.
AKfish
i have a 54" puma and used my son's tractor and blower last night to do his driveway while he's away. he has a 48" meteor....
the meteor (2yrs old) is not even close compared to the puma..... both were used in last nights 13"+ storm here in nh.... the meteor is on a larger (hp) machine and was bogging down. almost as much snow comes out of the side of the shute than out of the deflector, it does not throw as far, the unit is not as tall as the puma, and the shute deflector rotation handle
Sweet... LOL! :D 'Spose he's got a 1" hitch pin in there for the shear bolt..?
AKfish
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2011 TRAIL KING LOWBOY TRAILER (A51243)
2011 TRAIL KING...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2013 TIGERCAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGERCAT 720E...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
