Mechron 2200
/ Mechron 2200 #1
cjmitch
gold bridge b.c.
mechron 2200
Anyone have any trouble with the Mechron 2200 shift cable in cold weather .....mine seems to get hard to impossible to shift when it has been sitting in temps of 15F and lower.
once you warm it up by letting it run for 1/2 hour or so it shifts but not easily until it has been run for a while.....85 hours on it so far
wondering if my shift cable is on it's way out or can it be lubricated
Thanks for any help
Mitch
/ Mechron 2200 #2
Hey Mitch, havent heard from you for a while. As I recall, your dealer is couple hundred miles away. Can you remove the cable and dry it/lub it? Did you ever get a workshop manual?
/ Mechron 2200
Hi Rick,
Slow internet access here so I don't venture onto forums too much...I did finally get a workshop manual .....lubing the cable helped quite a bit, when it warms up I'll remove the cable and hang it to drain and lube it up and re install it so there are absolutely no droops or sags where moisture could accumulate
this thing is a great workhorse so far
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
