Mechanical Four Wheel Assist??
   / Mechanical Four Wheel Assist?? #11
Also, 4WD is only turning one front and one rear, unless the diff is locked in. With out the diff. lock, is is pulling with the 2 wheels that are easiest to turn.
   / Mechanical Four Wheel Assist?? #12
Tractors are either 4WD or FWA. That's four wheel drive. That's front wheel assist. 4WD tractors are traditionally used in broad acre farming. They are traditionally 150hp+. The key is that all wheels on a true 4WD tractor are the same diameter. These tractors are used in pulling rather than for their 3PL capability. In most instances these 4WD tractors run duals - that's 8 wheels in groups of two. A tractor like you are looking at (and like I own) have a smaller diameter front wheel. The front wheels can be driven. These tractors with a smaller diameter front wheel are FWA - that's front wheel assist. The manual on my tractor states that I can engage the mechanical four wheel drive. The manual is incorrect. My tractor is front wheel assist. I have a smaller diameter front wheel than on the rear. I may upset a few members here, but FWA is probably the most misused, as well as the most misunderstood technology. The easiest way to understand if the operator doesn't understand FWA, is to examine the front tyres of his FWA tractor. The front tyres will wear incredibly if the FWA has been improperly used. FWA is fabulous for engine braking on steeper ground. It's also fabulous for pulling, and for thrusting a bucket into a pile of dirt. Apart from that - it doesn't have to be engaged. The smaller front wheels must rotate at the same speed as the larger rears when FWA is engaged. Consequently the front wheels will always scrub. That causes the excessive wear. I see so many operators who have 4WA engaged all of the time - even when on hard surfaces or on the road. The wear that the transmission must cope with is incredible if FWA is engaged on a hard surface with the bucket of a FEL full. It's a real credit to the engineers who design these things. The FWA controller is probably the most used item on my tractor. FWA is fabulous. If you need it, then engage it. Otherwise don't have it engaged. My property is steep so I couldn't do without it. I would never, ever, ever have the fronts engaged whilst on a sealed road or a hard surface, and I would never engage the fronts after filling a bucket on my FEL. Manufactures are tending to call FWA Four Wheel Assist. I guess I can live with this. It's still front wheel assist but what it isn't is four wheel drive. There are front wheel assist tractors at the higher end of the market that can self-manage engaging the front wheels into drive mode. Sensors and computer technology manage the front wheel engagement if the rear wheels are sensed slipping. This changes nothing, as despite these tractors being over 100hp, the front wheels are still a smaller diameter than the rear wheels. It reinforces what I am saying - only engage the front wheels if required. Our local tractor mechanic has repaired a multitude of the cheaper Chinese front wheel assist tractors. When the front wheel assist is mis-managed on these cheaper units, something breaks. I have seen broken planetary drives in the front wheels, broken drive shafts and twisted and broken transmission shafts. The best was a clutch that had completely failed on a cheaper branded tractor. The unit was purchased new and had done 8 hours. Hope this helps.
Sent from my iPad using TractorByNet
   / Mechanical Four Wheel Assist?? #13
So, are you saying that if I put big tires on the front of my tractor, I will have 4wd?
I am not aware of any FWA controller on my tractor.
I have a true 4WD pickup. I don't leave it in 4WD on the highway.
On my tractor, the manual calls it 4WD. I leave it on most of the time in the dirt or mud. It is off on the highway. If I get into mud without it on, I will turn it on. One front wheel spins. With the diff lock engaged, I will have 3 wheels spinning. No diff lock on the front.
A lot of equipment does have diff lock on the front. Equipment with different front tires have different gear ratios on the front so that the tires covers about the same distance. Most front drive is set on equipment to pull about 5% or more faster. That is one reason that he will tear the grass up if it is engaged. Never leave tractors or trucks in 4WD on hard ground. It can do damage. When replacing the tires on a tractor, you should always use the proper size.
   / Mechanical Four Wheel Assist?? #14
I love these discussions. :)
4wd tractors are center pivot, all four tires same size, no disengagement, no difference in tire speed, absolutely no scuff.
FWA tractors are exactly what the name implies. Engaged to assist in low traction situations. Disengaged when not needed. Use a transfer case. Have varying amounts of pull/push geared into the setup. Scuff horribly. Require operator input. Benefit from operator knowledge and understanding.
   / Mechanical Four Wheel Assist?? #15
So, if a truck dealer calls a pickup 4WD they are wrong. And we should take all the tractor dealers and truck dealers to court to stop it.
I understand that it is not full time 4WD. And that it should not be used on hard surfaces. But the term four wheel drive has been used for years on a lot of equipment. And the big foot trucks do not center pivot. They have full time four wheel drive and 4 wheel steering.
Over time the accepted meaning of some items change. A lot of heavy equipment uses engine oil in the transmission and the hydraulic system. So is it engine oil or transmission oil? Depends on who you are asking. I have run large tractors 2WD and 4WD from the time I was 14. A friend up the road from me runs about 5 4WD tractors. From 2 to 20 years old. They never get taken out of 4WD. He never runs them on the highway. All are Deere between 50 and 125 hp. He has never had any drive problems that I know of.
   / Mechanical Four Wheel Assist?? #16
Yes and no....sometimes...
Yes, it may be only "turning" one front (if you're not moving), but still "pulling" with two fronts.
Both tires at each axle are applying the same TORQUE to the ground. It's just that not much torque can be applied to the ground through a tire that's spinning, and this same amount of torque being applied to the other side tire might not be enough torque to move the vehicle (using the wheel that has traction).
So while the stationary tire might not move vehicle, it's still applying the same torque that the spinning wheel is "catching". Or if it is enough torque to move vehicle, you think it's doing nothing because you don't see it spinning.
   / Mechanical Four Wheel Assist?? #17
4WD = something that has the SAME SIZE tires all around...
Front wheel assist is just that... "Usually" it's referring to that stupid hydraulic front assist drive that deer had for a time...
MFWD = mechanical front wheel drive, the tires are not all the same size tires and they are driven "mechanically"...
That's the way it was, until all the yuppie tractors came out for the wanna bee's… lol That started muddying up the terms...
SR
   / Mechanical Four Wheel Assist?? #18
Agree with the torque on the wheels, front and back. And thanks for the diff. lock on my tractors.
   / Mechanical Four Wheel Assist?? #19
While growing up, anything under 100 hp was a garden tractor. I now own a 50 hp. I no longer help on a 6,000 acre farm. I wouldn't call myself a yuppie, may a red neck. I have horses, may be a want to be rancher.
   / Mechanical Four Wheel Assist?? #20
I guess you file suit if you like.
The manufacturers "dummy" it down so us consumers can understand and accept it.
Not sure what a monster truck has to do with this. But since you threw it in the mix. My Son's tube buggy rock crawler is 4wd when engaged and it doesn't center pivot or rear steer. It gets completely weird when trying to turn a corner. Observers often comment that something is wrong with it. :)
My tube buggy rock crawler is 3wd when engaged. It too gets weird in turns but not as bad.
My Super Duty is 2wd when engaged. It dances around a bit in sharp turns but tolerable.
My Kubota is 2wd when engaged, until you step on the diff lock, then it's 3wd. Same with the Ford and little JD.
All of these are mechanically engaged. None meet the original tractor scenario of 4wd because they can be disengaged and do not center pivot.
Remember, terminology has been modified so we can comprehend it. And it sounds cool to say my truck is 4wd. Even when it never is. :)
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
CHAMPION OUTBOARD MOTOR (A58374)
CHAMPION OUTBOARD...
Caterpillar 740 HT-129 Tanker, S/N CAT00740PB1P009728, Cat Turbo Diesel Engine, Tidal Wave Tanks ... (A59076)
Caterpillar 740...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
