Mechanical Four Wheel Assist??
   / Mechanical Four Wheel Assist?? #21
4WD = something that has the SAME SIZE tires all around...
Front wheel assist is just that... "Usually" it's referring to that stupid hydraulic front assist drive that deer had for a time...
MFWD = mechanical front wheel drive, the tires are not all the same size tires and they are driven "mechanically"...
That's the way it was, until all the yuppie tractors came out for the wanna bee's… lol That started muddying up the terms...
SR
Very well stated Rob.
And even when they tried to dummy it down, many still don't get it. :)
   / Mechanical Four Wheel Assist?? #22
And that's why 4WD tractors should be actually called articulated tractors instead of 4WD tractors. :D
Calling it 4wd tractors can be misleading for some people. Specially with people used to the 4wd trucks and such.
   / Mechanical Four Wheel Assist?? #23
Yep. When I first started seeing them they were called Articulating. Then in my area it evolved to Center Pivot. Still called that now. :)
   / Mechanical Four Wheel Assist?? #24
WELL, if it has the SAME size wheels/tires all around, it's called a 4wd and my pu's have the same size tires all around!
Further more, two of them ARE 4wd and another is 3wd...
Same with one of my MFWD tractors, it IS 4wd!
SR
   / Mechanical Four Wheel Assist?? #25
Sometimes the term used is the one that rolls off the tongue the easiest.
   / Mechanical Four Wheel Assist?? #26
Absolutely. That's how we got in this discussion. :)
   / Mechanical Four Wheel Assist?? #27
When we sell a truck, it is not sold as a 4WD truck, but as an articulated dump truck. Almost all of the large construction and forest equipment is articulated 4WD or track. The only exception may be the backhoe. However, the backhoe may be the only one that we quote as being 4WD, due to it being the only one that can be purchased as 2WD.
   / Mechanical Four Wheel Assist?? #28
Articulation is the way to go with heavy equipment and/or high HP tractors.
   / Mechanical Four Wheel Assist?? #29
The XG3135 that has my interest at the moment has a Mechanical Four Wheel Assist according to the LS website.
XG3135H-35HP | LS Tractor
Is there a difference between that and MFWD or is it all just -- Whatever -- Marketing, terminology, branding....??
I searched and found this --
https://www.tractorbynet.com/forums...isons/320278-difference-between-4wd-mfwd.html
But reading that just left me scratching my head.
Dandruff :confused3:
Dandruff,
I'm not a post replying type of guy, but the 'Rona's got me bored, and last year I purchased the exact model of tractor you're looking at.
I had the same questions you do. And was as confused. So I went and drove many colors of tractor. I heard all the sale pitches until my head hurt.
What I found was that some had a hydraulic type 4wd system and some had a more traditional mechanical 4wd system.
I'm not a mechanic or a WDguru by any definition. But here's what I do know:
1. My LS performs as good as any tractor I've tested. I've got some pretty mushy fields next to creeks as well as some hills to brush hog. I've been moving dirt and clearing land. It'll go better than my '03 Jeep Rubicon.
2. The 4wd system has never let me down - of course I grew up with all 2wd tractors and did everything we needed to do with them, this one does so much more.
3. It performs much like my Jeep Rubicon. Both go great in 2WD, each appears to have limited slip diff when in 4WD, and each has the option to lock the diff.
4. It may sound simple... but there's this lever on Blue below my left thigh marked 2WD and 4WD. When engaged, the 4WD functions as to what I assume is a limited slip type drive. I have a cement pad at the top of a long steep gravel drive. I'm always in 2WD at the top to keep down wear on drivetrain and tires. If I have a load in the bucket and start down the cement portion of the hill and forget to switch to 4WD, I cannot control descent with the engine OR the brakes. Have you ever driven a 2WD tractor and hit just one of the rear brake pedals? That's what mine does if in 2WD going downhill with a load in the bucket. One tire locks up when braking. I've found that I must have 4WD for that downhill - it give so much more control with the engine and ... it may just be me, but it seems the brakes work differently as well.
4. There is an unmarked lever at the right heel on the foot platform. That's the differential lock. I have had the tractor in some very slick stuff and clogged the Ag tires - had to use the bucket with the "crab crawl" escape. One day I thought, "hey, what about that diff lock option, let's see what happens". Pressed down with the right heel and after a few revolutions of the tires the diff locked and it came right out with all 4 tires pulling at the same rate at the same time. I think you can use this in 2WD as well.
So I may be totally wrong in all of this, but it appears to me that this model of tractor has what most of us would think of as a limited slip differential in 4wd- meaning that the inside tires turn at a different revolution as the outside tires turning the tractor... but it has the option to lock the diff when needed so all pull at the same time at the same rate.
I hope that helps - ....and I'm sure I'm going to learn some new stuff after posting this reply. - be easy on me guys.
   / Mechanical Four Wheel Assist?? #30
Dandruff,
Your Rubicon has electric over air lockers in each axle. It also has a mechanical lever to select 2wd/4wd/4wd low.
Your tractor might have a limit slip front axle. That's not uncommon. Very rare to see a tractor with a selectable locker in the front axle. It definitely has a diff lock in the rear axle which is very common.
If you select 2wd and don't engage the diff lock you actually have 1wd. If you then engage the diff lock you actually have 2wd. If you select 4wd and don't engage the diff lock you actually have 2wd. If you engage the diff lock you actually have 3wd. Unless your tractor has a lockable front axle you never have 4wd.
John Deere 6120M (A57148)
John Deere 6120M...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
WHEEL WELL SHEET METAL (A58375)
WHEEL WELL SHEET...
DRAGON 500 BBL ACID TANK (A58216)
DRAGON 500 BBL...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
