Mechanical backhoe thumb
/ Mechanical backhoe thumb #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
Just installed a Titan backhoe thumb. Had to cut two 1/4" thick shims to build out the dipper stick, but then it bolted right on. Can't wait to try it out this weekend.:cool2::D
/ Mechanical backhoe thumb #2
Looks sharp! What do you plan to use it for? The limited swing angle seems like moving things with the backhoe would have limited use.
/ Mechanical backhoe thumb #3
You might want to slide it closer to the bucket. I have a weld on and I set mine where the teeth intersect at 90 degrees. I have to pivot it back for stump digging.
My main purpose is to pick up brush piles and load onto a trailer. Basically reach into the pile, grab a bunch and move / put onto trailer. Some piles have been sitting for 4-5 years....rattlesnake havens...
Other use will be to pick up and move some railroad ties.
I originally had it lower, but that limited the space I had between the bucket and thumb. I set it higher up so that I could grab a 'fatter' bunch of brush. I can move the teeth forward (towards the bucket) so that just the tips meet in order to 'pinch' also. I may move it down after I play with it a bit. Do you have a pic of yours?
/ Mechanical backhoe thumb #6
Careful picking up too much weight from the back end. Filling the front bucket full of dirt helps if your steering gets light.
A thumb on the front bucket would be more useful for moving piles but rigging the hydraulics seemed too much for me to do on my backhoe. I may still endeavor into that one day.
/ Mechanical backhoe thumb #7
Did you end up trying your thumb? how did it work for you? I'm needing a thumb to grab bedrock pieces off my shore line to move them to the back of my property. They are broken into pieces I can move by hand but not pick up so I was thinking the hoe could easily pick them up.
The thumb worked out great for picking up a large pile of brush and placing it in a trailer. Then used it to take RR ties off of a trailer, then place them for driveway / landscape beds. Unfortunately, I ended up selling the thumb with the tractor last spring.
I did not get one for the new tractor yet, I was waiting for LS to finally get the factory one out to dealers. My dealer now has them in stock and I will probably order one next month. They are a little more than the bolt on type ($330), but there are factory tabs already on the BH for it, and the bottom mounts to the bucket pin. The factory one can also be easily converted to hydraulic powered.
/ Mechanical backhoe thumb #9
Good to know I'll go that route then. I would rather have a factory one than something all hodgepodge onto it.
/ Mechanical backhoe thumb #10
I'll probably add a hydraulic cylinder to my mechanical thumb soon. I find that I am lazy and will not get off the tractor to adjust the mechanical thumb if I dont really need it. My only issues would be adding the hydraulic control valve. I'll cross that bridge when I get there. :)
/ Mechanical backhoe thumb #12
Maybe a diverter valve on the curl cylinder circuit? Or on the dipper cylinder circuit, so you could still close the bucket and thumb at the same time.
/ Mechanical backhoe thumb #13
You might be able to come right off the main feed, there is a ton of room under the platform.
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
Dueling Tree (A65640)
CrustBuster 3800 Grain Drill (A66285)
CrustBuster 3800...
