Measuring For A Toothbar
/ Measuring For A Toothbar #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
How accurate does the measurement for a bucket toothbar need to be? I've measured the inside dimension of my bucket with my trusty 25' Stanley tape measure and it's either 59 15/16" or 60".
/ Measuring For A Toothbar #2
I have not measured for a toothbar, but in doing windows (which I assume would be the same) we use the smallest measurement. I think you are very close at 59 15/16. You can shim it if it's a bit too small, but it's hard to cut material off if it's too big to fit into the bucket.
K
/ Measuring For A Toothbar #3
Very true...and if the bucket is a bit smaller back in where ya bolt it, it might give ya grief.
Mike, have you looked on Carver's site? I belive they go into the measurement aspect there.
Hi Roy,
Yes, I did check Carvers, in fact I just sent them an email. I measured my bucket at the front where it juts out (see picture).
/ Measuring For A Toothbar #5
I gave Carver the exact size I wanted and when it arrived it was approx. 1/2 inch short. As already mentioned, shims are easier than cutting off.
It is working as expected so far. Don't forget to floss. /w3tcompact/icons/grin.gif
/ Measuring For A Toothbar #6
Mike,
I'll second what Norris (gotrocks) said - my bar from Carver's came about 1/4" short from the measurement I gave them, and I just shimmed it with t couple of washers at each end. I'd give them the 60" dimension, and you should be fine.
Steve
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2022 EZ-GO ELITE...
