Rear Finish Mower Measuring finish mower blade height
   / Measuring finish mower blade height #1
Cutterman
Central Ohio
Massey-Ferguson 1540
What is the best way to measure the heights of the three blades on a finish mower? I have a Bush Hog RDTH72 (6') finish mower that has been giving me irregular cuts in recent years. I've got the blades off now to sharpen and would finally like to address the problem. The blades are in good shape: not bent, just dull.
   / Measuring finish mower blade height #3
youtube is your friend...
   / Measuring finish mower blade height #4
Blades should be even to the deck at both tip ends of each blade and the blades are probably even with each other. If not, you may have a spindle issue or a bent deck causing the spindle to be at a slight angle.
   / Measuring finish mower blade height #5
Try reading the instruction manual? My brush cutter cuts 1" higher than the sides per the instructions. Set the side height on level ground and my cut is 1" higher.
   / Measuring finish mower blade height #6
We generally cut at 3.5" so I took a 2x4 and cut off a 3.5" piece (making a square) and I slide that underneath the blades front and rear with the deck set at cutting height.
Aaron Z
19088 (A55758)
19088 (A55758)
17201 (A55852)
17201 (A55852)
2005 INTERNATIONAL 4300 SBA 4X2 FLATBED TRUCK (A58375)
2005 INTERNATIONAL...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
flatbed trailer 24ft (A56858)
flatbed trailer...
