Rear Finish Mower Measuring finish mower blade height
   / Measuring finish mower blade height #1
Cutterman
Central Ohio
Massey-Ferguson 1540
What is the best way to measure the heights of the three blades on a finish mower? I have a Bush Hog RDTH72 (6') finish mower that has been giving me irregular cuts in recent years. I've got the blades off now to sharpen and would finally like to address the problem. The blades are in good shape: not bent, just dull.
   / Measuring finish mower blade height #3
youtube is your friend...
   / Measuring finish mower blade height #4
Blades should be even to the deck at both tip ends of each blade and the blades are probably even with each other. If not, you may have a spindle issue or a bent deck causing the spindle to be at a slight angle.
   / Measuring finish mower blade height #5
Try reading the instruction manual? My brush cutter cuts 1" higher than the sides per the instructions. Set the side height on level ground and my cut is 1" higher.
   / Measuring finish mower blade height #6
We generally cut at 3.5" so I took a 2x4 and cut off a 3.5" piece (making a square) and I slide that underneath the blades front and rear with the deck set at cutting height.
Aaron Z
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
MISC TIRES (A54757)
MISC TIRES (A54757)
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
