MinnesotaEric
Super Member
I used the word "pound" for lack of a better term. What happens with my method is that the end of the set screw gets pushed into the shaft and therefore loosens the set screw. This will work on the gear too as long as you don't "pound" the gear hard enough to crack it. All you want to do is push the set screw into the shaft a bit. "Pounding" from the end if you have room loosens the threads of the set screw if they are slightly seized which is common.
Many farmers in this area have thanked me for developing this method of removing set screws. It makes changing a bearing a few minutes job instead of getting out the cutting torch or cut off saw so that you can remove the bearing. Quite often the lock collar can be reused after doing the punch and hammer method on set screws.
We call the technique of wailing on the rusty bolt or set screw, "shocking." You shock the rusty bit to break the rust. If it doesn't come loose, then heat and cold water to break the rust. Repeat as necessary avoiding the cutting torch or drill.
