Mckee Snowlander 320 Parts manual
   / Mckee Snowlander 320 Parts manual #21
I used the word "pound" for lack of a better term. What happens with my method is that the end of the set screw gets pushed into the shaft and therefore loosens the set screw. This will work on the gear too as long as you don't "pound" the gear hard enough to crack it. All you want to do is push the set screw into the shaft a bit. "Pounding" from the end if you have room loosens the threads of the set screw if they are slightly seized which is common.
Many farmers in this area have thanked me for developing this method of removing set screws. It makes changing a bearing a few minutes job instead of getting out the cutting torch or cut off saw so that you can remove the bearing. Quite often the lock collar can be reused after doing the punch and hammer method on set screws.
We call the technique of wailing on the rusty bolt or set screw, "shocking." You shock the rusty bit to break the rust. If it doesn't come loose, then heat and cold water to break the rust. Repeat as necessary avoiding the cutting torch or drill.
   / Mckee Snowlander 320 Parts manual #22
Thank you Eric for setting me straight on this :). I learned something again.
It's interesting how everyone kind of has their own favourite way of doing things. You use heat and cold water which I can see working quite well. I like to use heat and a wax candle which also works.
   / Mckee Snowlander 320 Parts manual #23
Has anyone every tried liquid nitrogen in these rust frozen situations?
I saw a video of it being used to break a padlock.
Warm up the collar or gear just a bit and then a drop or two of liquid nitrogen on the set screw.
It is -321 F as it boils at room temp.
That should shock the rust!
Dave M7040
   / Mckee Snowlander 320 Parts manual #24
I have not worked as an auto tech for years now, but in a shop the torch is right there for heating as is a hose. If repeated attempts to heat and cold don't work or the fastener striped out the heating tip is swapped out for a cutting torch. Exhaust systems we skipped the water and went straight to cutting except on headers.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
