McCormick GX45, number of plows?
   / McCormick GX45, number of plows? #1
b6200hst
Western Pennsylvania, Brookville
McCormick GX45, Kubota B6200HST-E
Hello, I know this question gets asked alot, but, I will ask again for MY tractor. I have a McCormick GX45, manual transmission, 44hp, 4wd, FEL, ag tires, weighs in right around 4200 lbs with loader. The tires are not loaded and I have no weights anywhere. I will be plowing a relatively loose soil, some recently plowed, some with a decent sod built up (old hay field). Should I just stick with maybe a 10" or 12" 2-bottom or do you think I could move up to a 3-bottom plow?
Thanks for any input.
   / McCormick GX45, number of plows? #2
You could easily pull 2X14" or 2X16", MAYBE even 3x12" or 3X14" if conditions are absolutely perfect. But....You're a little "light" for 3 bottoms in many conditions. (ie sod ground) MFWD will overcome some of the lack of weight, but how much is questionable.
Myself? Unless I had (literally) hundreds of acres to plow, I'd go 2-bottom (14" or 16") and pull it EASILY, and at a moderate speed. I've always found it to be more productive pulling a smaller plow faster, rather than struggling along with a big plow. Speed (around 5mph) will net you a better plowing job.
A simple solution....Find a 3-bottom plow, try it, and if it's too much of a load, remove the rear bottom (to make it a 2-bottom plow)
Again, IMHO, you'll struggle with 3 plows (and that HP/weight tractor) in many instances. I'm certain someone will chime in about how "back in the day" they pulled 3 and 4 bottoms with 45hp. That was likely with a tractor that weighed 8,000 to 10,000lbs, and was moving along @ 2-1/4mph. "Modern plows" (ie those built post WWII) don't like to be pulled that slow.
Spinning Bolt/Nail Bin (A57454)
Spinning Bolt/Nail...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A57453)
2007 Chevrolet...
ST235/80R16 Truck Tires (A56860)
ST235/80R16 Truck...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
