Oil & Fuel McCormick CT-41 Tractor
/ McCormick CT-41 Tractor #1
HarleyRiders97
Wayne County, Pennsylvania
McCormick CT41
Hello all: was wondering if anyone here has a McCormick CT-41 tractor. I have one with the Mitsubishi 4 cyl. 2.3 L diesel engine. I am in the process of the first oil change and noticed that the engine appears to have two distinctive oil reservois. According to the owners manual it shows only one. Does anyone know if both of the retaining bolts need to be removed to drain all the oil? Thanks so much for your input!
/ McCormick CT-41 Tractor #2
If you are talking about a split oil pan where the front drive shaft goes in between, then yes remove both.
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Hydraulic rail grinder (A61307)
Hydraulic rail...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
