May have blown a head gasket?
/ May have blown a head gasket? #1
tomcase580b
Bronze Member
manorville
case 580b
Yesterday I was pushing my mid 70's case 580 b ck too hard in the mud. The temp went up and a good amt of antifreeze came shooting out of the overflow tube that is connected to the fill neck. The machine cooled down I replaced some of the antifreeze, and ran it lightly for about another half hour with no issues. The temp held at around 180. I talked to someone today who told me to start the machine with the radiator cap off to see if there was any violent bubbling, that would tell me id i had a blown gasket or worse a cracked block. tonight when i got home I did just that, but i noticed i have an slight oil leak now from under the radiator (not the radiator) but from underneath. I ran the machine for about an hour. light work...it never overheated. I guess it's time to learn how to take the hood off and diagnose the oil leak. If anyone can give me some advice on what to look for i would appreciate it.
/ May have blown a head gasket? #2
You'll probably be able to see more pulling the grill, to look under the radiator. And/or at least put a trouble light down there to shine, and look in from the top with the hood off. Hyd. pump is there with your large pressure and feed lines.
I do recall when ordering a new radiator for my 480C, there was a listing for one with oil cooler lines, and one w/o. Not sure what was available on the 580B. Guess you could check through Case Construction Parts online.
ya know i was just out there looking again and what you said makes sense... i think it may be leaking hydro fluid from either the pump or the lines...i know the previous owner replaced the pump, and when i just checked it it looked more like hydro fluid than oil...(forgive me i'm not a mechanic)...for all i know it's been leaking since i own it...and it's only a few drops...i'm going to pull the grill this weekend and check...
Landhonor Quick Attach Brush Mower (A66408)
Landhonor Quick...
Barrel (A64557)
Barrel (A64557)
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
JOHN DEERE 7200R TRACTOR (A64278)
JOHN DEERE 7200R...
