Maxing out drawbar capacity
   / Maxing out drawbar capacity #1
pretendfarmer
WA
John Deere 790
My JD 790 rates the max drawbar hitch weight at 675 lbs. I want to move a small travel trailer around a flat driveway but am unable to weigh the tongue. From everything I can find, the travel trailer tongue weight should be between 600 and 700 pounds per the manufacturer. Is there some leeway built into the drawbar ratings?
   / Maxing out drawbar capacity #2
You won't break the drawbar hitch, but the front end may get light. That you will find out when you hook up to the trailer.
Just be prepared to either add weight to the trailer behind the axles, or to add weight to the front end of the JD 790.
A bit of trial and error. But think it should go well for you.
Let us know..
   / Maxing out drawbar capacity #3
I'm sure you will be fine, but as mentioned, be careful with the front end getting light.
If you want to measure your tongue weight, there are methods using a regular bathroom scale and a lever. I use a small hydraulic scale just for my trailers to ensure I get the tongue weight correct when loaded.
   / Maxing out drawbar capacity #4
Often the height and length of the drawbar are limiting factors.
Your rear tires will get close to the trailer and a frame on turns.
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2021 Mercedes-Benz Sprinter 4500 (A51692)
2021 Mercedes-Benz...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
