Maximum pressure Oil Pressure Guage
   / Maximum pressure Oil Pressure Guage #1
indigob
North Central TX
Mahindra 4530
I am having a problem with the Oil Pressure Guage on my 4530. It is pegging
to the maximum far right when running or even just when the key is turned on but not running. Any suggestions? Thanks in advance.
   / Maximum pressure Oil Pressure Guage #2
Either the sensor is bad or the wire from the sensor to the guage is grounding out somewhere.
Thanks Galen. My service manual does not tell me where the sensor is
or how to identify it. I am guessing it is the cylindrical shaped unit
about the size of a ring box with a single green wire attached to it.
Is this correct? Also, I removed the insturment panel and cleaned
everything and reassured the connections, then tightend the screws
for the insturment panel.
Thank you,
Peter
I should add that it is on the right side (as I'm sitting on the tractor) about midway up the engine block and a little forward of the brake pedals.
   / Maximum pressure Oil Pressure Guage #5
That should be correct. It should be near the oil filter.
   / Maximum pressure Oil Pressure Guage #6
I bet it works on resistance of the circuit. Look for a chewed wire, or an oil leak on the sender.Jy.
OK, thank you Galen and JY. I beleive it is close to the
oil filter. I will check it tomorrow.
BTW, any Veterans who see this post,
THANK YOU FOR YOUR SERVICE & SACRIFICES!
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
