Maximum pressure Oil Pressure Guage
/ Maximum pressure Oil Pressure Guage #1
indigob
North Central TX
Mahindra 4530
I am having a problem with the Oil Pressure Guage on my 4530. It is pegging
to the maximum far right when running or even just when the key is turned on but not running. Any suggestions? Thanks in advance.
/ Maximum pressure Oil Pressure Guage #2
Either the sensor is bad or the wire from the sensor to the guage is grounding out somewhere.
Thanks Galen. My service manual does not tell me where the sensor is
or how to identify it. I am guessing it is the cylindrical shaped unit
about the size of a ring box with a single green wire attached to it.
Is this correct? Also, I removed the insturment panel and cleaned
everything and reassured the connections, then tightend the screws
for the insturment panel.
Thank you,
Peter
I should add that it is on the right side (as I'm sitting on the tractor) about midway up the engine block and a little forward of the brake pedals.
/ Maximum pressure Oil Pressure Guage #5
That should be correct. It should be near the oil filter.
/ Maximum pressure Oil Pressure Guage #6
I bet it works on resistance of the circuit. Look for a chewed wire, or an oil leak on the sender.Jy.
OK, thank you Galen and JY. I beleive it is close to the
oil filter. I will check it tomorrow.
BTW, any Veterans who see this post,
THANK YOU FOR YOUR SERVICE & SACRIFICES!
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
2022 EZ-GO ELITE...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
