Maximum load for three point hitch
/ Maximum load for three point hitch #1
fiddlerkelly
kubota b2630
I have a 2006 B2630 kubota. I have a cat 1 - 3 point hitch. I want to make a couple of attachments to connect to my 3 point hitch , plans on making a box to attach to it for getting ie. wood and moving things , also making an attachment for hitch so I can haul a small trailor forcattying rocks and gravel. What is the maximum load I can connect to my 3 point hitch.
/ Maximum load for three point hitch #2
What does your manual say?
I dont think tractor data's specs are accurate as it says 2,139# at the ends and 1,676# at 24" back. Which is more than the Economy L series tractors can lift (which them tractors also weigh 900# more and have alot larger axles.
And unless you have front weights or a loader.....you wont come anywhere close to the max without popping a wheelie.
/ Maximum load for three point hitch #3
What does your operator manual say. Don't have an op manual - get a copy from your local Kubota dealer. It has a wealth of good information.
/ Maximum load for three point hitch #4
Tractor Data www has listings for most tractors. Numbers are specified as to where the measurements are made....usually at the pins with OEM lift arms or a specified 6" or 2' behind the pins. If you do after market lift arms that are longer than OEM then the number is reduced due to the length....foot-lbs thing.
Usually your tractor front end will come off the ground before the 3 pt runs out of whoopie. So, in making your determination you have to factor in how you are going to load the front. If you have a FEL and a bucket it's easy as you just fill the bucked with enough dirt or rocks till it stays on the ground and is safe.
Deutz D3006 Tractor (A62613)
Deutz D3006...
2011 Cadillac Escalade 4x4 Ext. Cab Pickup Truck (A61573)
2011 Cadillac...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
