Maximum horizontal distance between lower and upper link holes
   / Maximum horizontal distance between lower and upper link holes #1
wwwfarmer
Hello everyone!
I am constructing a 3pt hitch for an implement and was wondering if there is a limit on how far apart should lower and upper link holes be? Take a look at the image from the side:
My current setup has 16" (40cm) vertical distance and 6 1/2" (around 16cm) horizontal distance. Would that do for most tractors of cat. 1 and 2?
   / Maximum horizontal distance between lower and upper link holes #2
One source shows 18" for the CAT1 and 19" for CAT2 as standard. Probably other info at other places though. One thing to consider is how the spacing will affect the way the implement behaves when lifting it.
   / Maximum horizontal distance between lower and upper link holes #3
Try and match your tractor and the closer your can the load well stay leveler. If you get it to high it could hit the back of the tractor and the load would be tilted fwd and the lower link arm are not all the way up. I made all my stuff at 16".
   / Maximum horizontal distance between lower and upper link holes #4
Why do you have the horizontal offset?
I won't work with a Quick Hitch:
I think most are in the same vertical plane:
   / Maximum horizontal distance between lower and upper link holes #5
When you build something, why not make it to standard dimensions? Even if you don't use a quick hitch now, you might someday.
Bruce
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
MULCHER (A58214)
MULCHER (A58214)
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
Ford 8510 (A53317)
Ford 8510 (A53317)
