MaxBrake Brake Controller Questions
/ MaxBrake Brake Controller Questions #21
I have a Max-brake.
It works perfectly. I'm not worried about any of the fittings.
I installed it, calibrated it and used it. No need to reset anything whether your trailer is loaded or empty or going from one trailer to the next.
Other than the calibration, the only adjustment there is determines how fast the trailer brakes react to pedal pressure, either before the truck or after.
This is the only controller I have personally owned but I've pulled a lot of trailer with borrowed trucks and I hated the controllers.
My Brother in Law has 3 rigs and after using my truck and experiencing my controller, he has replaced all of his controllers with Max-brake
/ MaxBrake Brake Controller Questions #22
Thanks Allen
Good to hear someone who has experience with both types and loves the Brake Max. My next new truck will have one if not equipped with a Factory Unit. I am like you. I have used them all from Prodigy, Reese, ect and was happy until I tried a pressure drive system like the factory ones Ford puts on. It was hands down no comparison.
Chris
allen - I still have the unit and may install it on my other excursion as a test since this one is used only by me and my wife and kids don't ride in it with me. I am happy to get a positive review from someone who has experience with the product. How long have you had it installed?
/ MaxBrake Brake Controller Questions #24
I have had the Max-brake for a couple of months now.
Just so you know, the hardest part of my installation was getting the wires through the firewall.
I pulled an existing grommet and fed it through that. It was just tough to get to it.
Here's an example of how it works. I loaded (accidentally) 12,880 lbs of dirt in my 14,000 GW dump trailer. I never touched the controller before the trailer was loaded, while loaded or after I dumped it. It stopped perfectly. I have mine set to where I begin to feel the trailer brakes just before the truck brakes.
It's expensive but in my mind, well worth it.
/ MaxBrake Brake Controller Questions #25
I will just weigh in with my $.02 worth!
The problem I see with NPT fittings, is that you may have trouble getting them tight AND to the proper orientation. It seems like that is the biggest problem I run into. A NPT fitting seals based on thread interference, and tape just takes up some of that "space" so it seals better. And in an automotive application where working space is at a premium, well, you be the judge on that!
Overall a proper flare fitting seems like a much easier and reliable (leak wise) attachment to make.
I would seriously doubt teflon tape is going to be attacked by any automotive fluid, teflon is used in all kinds of chemical applications. One thing you are probably already aware of, but make sure, when you wrap the threads, you don't wrap the first thread, IOW, make sure you won't get any FM from the teflon inside your lines.
/ MaxBrake Brake Controller Questions #26
Since my original post about the maxbrake, I'm still a happy "leak-free" owner. Would not trade it for anything short of a new F450 :) Got to drive an 08 F450 king ranch p/u over the weekend and d**n, it was nice.
/ MaxBrake Brake Controller Questions #27
Get the new 450 with the factory controller and you would not have to worry about anything.
Chris
/ MaxBrake Brake Controller Questions #29
I was hoping you would just pick up two when you got yours and send one my way.:D:D:D:D:D:D:D:D:D:D
Chris
/ MaxBrake Brake Controller Questions #30
FYI, In a few earlier post I read where there was serious concern about compression fittings in brake lines. I too am of the school they are BAD. But an auto mech friend of mine told me about the steel DOT compressions available at NAPA. I have used them and have to say they work well. They are all steel and have a ferrel like aircraft flare fittings do. They can really save you alot of work replacing a line. Especially on the road. If you drive an older vehicle put some in the glove box. Already saved my but on a trip last year.
/ MaxBrake Brake Controller Questions #31
Chris
Would love too. If you've got $30000.00 worth of excavation/construction work, we'll take the job....Bill you for $85000.00 and give YOU a FREE 2008/9 Ford F450 xl 4x2, std., diesel dually. :) And, luckily for you, we currently have some unfilled immediate openings :D
BTW, this is not a one time promotional offer. I would make the same deal for anyone reading this living east of IL, south of canada and north of the gulf of mexico. Some additional fees may apply. Warranty not expressed or implied. Free vehicle subject to owner paying all dealer added options, applicable state taxes and licensing fees. Fuel surcharge may apply to location and free vehicle. Adult beverages and entertainment to be solely provided by property owner. Some exclusions and/or limitations may apply. Weather permitting, etc., etc.,
/ MaxBrake Brake Controller Questions #32
No deal. I want the top of the line FX4 or King Ranch and it has to be a 4x4 with a automatic tranny.:D
Chris
/ MaxBrake Brake Controller Questions #33
That could easily be arranged with some minor contract modifications.....
2012 HAMM PADFOOT ROLLER (A62129)
2012 HAMM PADFOOT...
2020 PETERBILT 567 (A60736)
2020 PETERBILT 567...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
