Max tongue weight on a Steiner 430
   / Max tongue weight on a Steiner 430 #1
garry
Ohio
JD 1050
Can anyone tell me what the max tongue weight on an old (1997) Steiner 430 should be. Specifically I want to know if it is OK to pull a trailer with a tongue weight of 250 pounds.
   / Max tongue weight on a Steiner 430 #2
I don't think that would be a problem at all. That's only the equivalent of a man standing on it.
   / Max tongue weight on a Steiner 430 #3
One thing you have to consider, besides tonque weight, is towing capacity. My Steiner 525 had no issue with tongue weight of a leaf rake, but it knew it was back there when chopped up leaves filled that hopper! Even worse if the leaves were slightly damp!
   / Max tongue weight on a Steiner 430 #4
If you are concerned about the axles, you could remove the rear weights to compensate for the extra weight on the back.
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
24in excavator tooth bucket (A56436)
24in excavator...
403 (A52706)
403 (A52706)
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
