Max 26 - finish mower size
   / Max 26 - finish mower size #11
I have a max 26. Ran a 5 foot woods finish mower just fine . The Woods was heavy
   / Max 26 - finish mower size #12
Did you get your Max 26 just without the mid mount mower, or without the mid PTO to run it? I kind of like having the mid mount mower on mine. After running a 5' brush hog on the rear I could foresee some maneuvering advantages to the mid mount Mower over a 3 point. Depends on your mowing area though.
No mid pto. I decided against the mid mount mower because I will be doing a lot of loader and backhoe work on uneven terrain and in the woods. I was concerned with the mid mount getting hung up and was not crazy about the idea of removing it every time I do that kind of work.
Plus, the dealer was able to get me a machine in that configuration right away from another dealer vs. waiting an unknown amount of time to get one from the factory.
It seems I will be going with the 60" at a minimum. I just need to decide if I will roll the dice on a 72". If I go used it will be easier on the wallet if it turns out to be a mistake.
   / Max 26 - finish mower size #14
You might check the blade tip speed required to cut the type of gass you will be cutting VS the blade tip speed of the mower you are looking at.
I ended up buying a used Frontier GM2072, 72" finish mower. After 2 days of working on the deferred maintenance items I did my trial run. It did a great job with my Mahindra Max26. I used low range and went slow. It still cut my mowing time significantly. Plus the section I tested on was overgrown with 6”-8" bullthistle. Bullthistle is a tough flowering weed. It is rear discharge and I could barely see any clippings.
   / Max 26 - finish mower size #16
I have a 2516 and love using my 6 foot Farmking finish mower. It will bog down in high grass. Sharp blades help. I definitely needed and have front suitcase weights. The weights come off then I attach the loader, which is only a mild inconvenience…no bracket interference.
   / Max 26 - finish mower size #17
I purchased a Max 26 without the belly mower. I will get a 3pt finish mower for it. The dealer said the recommended implement size is 48" for basically everything except a rake. I find it hard to believe this 26hp machine can't handle at least a 60" 3pt finish mower. Does anyone have real world experience to help guide me in selecting a finish mower?
I have a max 26 xlt with a 60” Sitrex rear finish mower. It runs it no sweat.
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
Toro Workman Utility Cart (A51694)
Toro Workman...
