Mattock Handles. Why?
   / Mattock Handles. Why?
@California They are practically identical. When I saw your post I went right down to my shop and put the wire wheel on mine. But, I cannot find any stamped letters of any sort.
   / Mattock Handles. Why? #32
Great info. Thanks guys.
But I have to say, it isn't very practical from a use standpoint. I've used them where the head slid down the handle at the top of the upstroke.
I have a newer one where the design is the same but there is a rubber collar around the top of the handle that fits into the head and holds the head in place. It works pretty well
With this little one I wonder if putting a wedge in the top of the handle would work. I don't see how it could hurt.
with the age the wood shrank causing the head to slip … with your new handle place it in a very dry place before shaping it then once it’s in the ambiante air it will gain humidity and swell up so this dosent happen …
   / Mattock Handles. Why? #33
I do not have any hickory but I do have several freshly cut ash logs waiting to be cut on the saw mill. I think ash would work okay. I'll cut out a rough blank but I'm not sure how long the blank will need to dry before I put it on the lathe?
roughly shape your handle and put it by a heather in your house ( a very dry place) id say a month should be sufficient if it’s pretty warm and dry but not 100% as for the time required but i would weight it at the beginning and once you see the weight stabilize it’s good to go then you finish your moulding and installed and once outside it will regain humidity and swell up to seal it in place.
   / Mattock Handles. Why? #34
Why are mattocks not fixed on their handles? In other words, why aren't they fitted like axe handles, pick handles and sledge hammer handles? The old mattock I have has two nails in the handle under the head to keep it from slipping down. Been that way since I was a child.
I'm asking because I recently got a mattock head from my father-in-law's garage. It is less than half the size of a normal mattock which is really cool. It has some surface rust but is otherwise in great shape. I'm going to clean it up and make a handle for it. I have a lathe.
The opening for the handle is round but slightly cone shaped like a normal mattock so that the handle is installed from the top and is supposed to snug down on the handle which is also slightly cone shaped.
I'm just wondering if I should install the handle that way or should I consider wedging it like an axe handle.
Any advice appreciated.
Inertia keeps the head in place. Prying forces will not slip the head off of the handle.
Only if you are swinging it like a bat with every swing. Not very realistic in my experience.
I've got the ash slabs in the basement. Will cut a blank out soon since it will dry faster than the slab. Will give it a try putting near the heat but the cold weather is going to be gone soon so I might just leave a fan blowing on it.
   / Mattock Handles. Why? #37
I have a martha that is pretty dry, I hope it works out okay.
I'm not saying that a full swing from over the shoulder is wrong. I just don't very often find myself in a situation where that is possible the whole time. There's always branches over head, someone else nearby, the wall of a ditch behind me, etc etc etc.
Pull Type Garden Wagon (A50860)
Pull Type Garden...
2014 Forest River Crusader 295RST 32ft. 5th Wheel T/A Travel Trailer (A48082)
2014 Forest River...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2003 John Deere 1600 Turbo Ride On Mower (A50860)
2003 John Deere...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
