Massey mf40 backhoe help with engine
   / Massey mf40 backhoe help with engine #1
pbpimp06
burleson tx
ford 871
I rebuilt the motor I had the injectors rebuild also but motor sounds very sick sounds like it's running off maybe 2 shoot might be just the one it's a 3.152 Perkins in it how do you tell if the injectiors are not right or what would y'all think it could be ?
The injection pump never came off so it wouldn't be out of time right ??
Thanks Chris
   / Massey mf40 backhoe help with engine #2
The Shop I worked in had an injector tester. It was just a hand pump and a fitting to connect to the injector. I would get the injectors tested. sounds like they did a bad job or they picked up some dirt along the way, through the lines or in shipping. Ed
   / Massey mf40 backhoe help with engine #3
Did you prime the injectors? If not then they could be trying to inject air.
   / Massey mf40 backhoe help with engine #4
I had a silinderhead rebuild and they forgot to shortern the valveguides.......rockers bent and engine missed .
   / Massey mf40 backhoe help with engine #5
Ouch! Hope they fixed the engine for free. Did the valves hit the cylinders?
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
UNUSED RETRACTABLE GARDEN HOSE REEL (A54757)
UNUSED RETRACTABLE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
EXCAVATOR HYD HAMMER (A51406)
EXCAVATOR HYD...
