Massey mf40 backhoe help with engine
/ Massey mf40 backhoe help with engine #1
pbpimp06
burleson tx
ford 871
I rebuilt the motor I had the injectors rebuild also but motor sounds very sick sounds like it's running off maybe 2 shoot might be just the one it's a 3.152 Perkins in it how do you tell if the injectiors are not right or what would y'all think it could be ?
The injection pump never came off so it wouldn't be out of time right ??
Thanks Chris
/ Massey mf40 backhoe help with engine #2
The Shop I worked in had an injector tester. It was just a hand pump and a fitting to connect to the injector. I would get the injectors tested. sounds like they did a bad job or they picked up some dirt along the way, through the lines or in shipping. Ed
/ Massey mf40 backhoe help with engine #3
Did you prime the injectors? If not then they could be trying to inject air.
/ Massey mf40 backhoe help with engine #4
I had a silinderhead rebuild and they forgot to shortern the valveguides.......rockers bent and engine missed .
/ Massey mf40 backhoe help with engine #5
Ouch! Hope they fixed the engine for free. Did the valves hit the cylinders?
2010 Honda Accord Sedan (A66738)
2010 Honda Accord...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2012 FOREST RIVER SALEM (A67714)
2012 FOREST RIVER...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
