Massey Ferguson Transmission Filter Screen?
   / Massey Ferguson Transmission Filter Screen? #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
MF 5465 has a dash light that comes on just as soon as the tranny warms up. According to the operator's manual it says something about a 15 micron transmission screen/filter may be blocked. Any idea where or what this may be?
Also trying to figure out what trouble code 14 is. Anybody?
   / Massey Ferguson Transmission Filter Screen? #2
Don't know about the 5645, but my teensy 2310 has a filter screen in the suction side of the hydraulic system which is located behind the left rear wheel and is accessed by a large nut on the cap. (This is in addition to the hydraulic filter.)
I'll bet yours has something similar. Here are a couple pics of mine: I'm holding the tube-shaped screen by the nut end that unscrews in one pic; in the other, you can see the hole where it came out of the tractor in the background, directly behind the tip of the magnet rod I stuck in to collect metal particles. Hope this helps.
View attachment 394359View attachment 394360
That's great. Thanks a lot. I'll have to see what I can find.
BTW, have you ever seen a list of MF error codes and description? I cannot seem to find them anywhere online.
   / Massey Ferguson Transmission Filter Screen? #4
"a list of MF error codes" Nope, can't help you there. My 2310 is too small (and likely too early) for all the electronic jazz. You should try to order a factory service manual from a local dealer (or direct from the factory, for that matter). They're not cheap, but will pay for themselves very quickly.
Looks like your 5465 has a Finnish-made diesel; that should be a very well-made engine. Your PTO HP is over 5 times what mine has!
irvingj
There are actually 2 different diesel for the 5465. They changed in 2008 from 6.0L Perkins to 6.6L Perkins. But it seems like I recall something about a Sisu diesel as well.
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
434669 (A48836)
434669 (A48836)
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
