Massey Ferguson GC2300 slow cranking when hot.
   / Massey Ferguson GC2300 slow cranking when hot. #1
Solaris1952
Greetings, Last summer my GC2300 with FEL started cranking slow when hot. I don't mean overheated but hot after normal use for 30 minutes or so. If I shut it off when hot it will not crank fast enough to start it until it cools down. The tractor starts easily even in cold weather when the engine is cool. About 2 summers ago I replaced the starter with a cheap replacement from Amazon so I was thinking it was the cheap starter. This last winter while doing other repairs on the tractor I replaced the starter with a more expensive one that was advertised as 'High Torque' but the issue still exists. Personally I think the starter is still the problem but would like to hear if someone has other thoughts.
Harry
   / Massey Ferguson GC2300 slow cranking when hot. #2
Have you load tested the battery?
No, I don't have the tools to do that. Can I take the battery to Autozone and have it load tested without being in the tractor?
Harry
I will add that I do keep a battery tender on the battery 24/7 and it has the most cold cranking amps I could get for the size of battery it is.
   / Massey Ferguson GC2300 slow cranking when hot. #5
Harry
Check the battery cables. They cab corrode internally. Make sure the battery connections and especially the chassis ground is "bright and tight".
Harry
Yes an auto parts store can usually do that.
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
