Massey Ferguson disc set
/ Massey Ferguson disc set #1
LabLuvR
SC
Kubota MX5400
I am looking at a set of disc, for my 37 hp Kubota that weight 845 lbs with 20, 18" disc. I like the set except that to adjust the angle you have to remove a bolt. For various reasons I adjust my current set quite often and to do so all I have to do is remove a pin. Could I replace the bolt with a pin without doing damage? For those of you who have Massey disc what is your opinion of them? Thanks!
/ Massey Ferguson disc set #2
If it is made the way that I think that it is, it would be fine to use a pin.
/ Massey Ferguson disc set #3
I had ( have ) a ford dual ganged set that changed angles with a bolt.. and currently has an "L" shaped piece of rebar inthere right now /forums/images/graemlins/shocked.gif
Pin sounds fine.. get one with a hairclip .. etc.
Soundguy
Thanks guys! I think I just decided on what to buy!
213088 (A64276)
213088 (A64276)
Ditch Witch Mixing System FM13V (A65579)
Ditch Witch Mixing...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2011 PETERBILT 367(INOPERABLE) (A65643)
2011 PETERBILT...
RHINO 127 - 7' OFFSET DISC HARROW (A64277)
RHINO 127 - 7'...
2020 Polaris Ranger XP 1000 UTV (A65579)
2020 Polaris...
