Massey Ferguson disc set
/ Massey Ferguson disc set #1
LabLuvR
SC
Kubota MX5400
I am looking at a set of disc, for my 37 hp Kubota that weight 845 lbs with 20, 18" disc. I like the set except that to adjust the angle you have to remove a bolt. For various reasons I adjust my current set quite often and to do so all I have to do is remove a pin. Could I replace the bolt with a pin without doing damage? For those of you who have Massey disc what is your opinion of them? Thanks!
/ Massey Ferguson disc set #2
If it is made the way that I think that it is, it would be fine to use a pin.
/ Massey Ferguson disc set #3
I had ( have ) a ford dual ganged set that changed angles with a bolt.. and currently has an "L" shaped piece of rebar inthere right now /forums/images/graemlins/shocked.gif
Pin sounds fine.. get one with a hairclip .. etc.
Soundguy
Thanks guys! I think I just decided on what to buy!
Adams 5 T Fertilizer Spreader (A63118)
Adams 5 T...
2017 TOYOTA TUNDRA(INOPERABLE) (A63569)
2017 TOYOTA...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59910)
2007 KOMATSU...
Kubota L2501 (A62177)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
