Massey Ferguson 35 older Model
   / Massey Ferguson 35 older Model #1
firstagchurch
I have a Massey Ferguson 35 older Model (60's) and it is stuck in 2nd gear. I have always been able to get it unstuck before but this time I haven't in spite of trying everything I knew to do. Can someone out there give me some advice and direction that will help me
with this situation. I would certainly appreciate it.
Thanks
Donnie D.
Arkansas
   / Massey Ferguson 35 older Model #2
Doesn't this model have the gear shift lever you can pick up enough it will clear the shifter slots in the transmission? Think you will find it does. If so you need to remove the top plate (shift lever is mounted in it) and look carefully until you see (will be just below where the shifter enters the transmission) the two slots which will form a single wider slot when both are in alignment. Slide them so both are in aligned with each other. Should be where you can reassemble and be able to not freely shift. Just don't pull on the shifter lever and you probably will not have the problem.
   / Massey Ferguson 35 older Model #3
is it stuck in 2nd, or stuck in 2nd and some other gear thus binding.
if it's in 1 gear only, not a big deal to remove cover and pry back o neutral, then check the shift pattern and nub .. etc.rails, forks and detents for wear.
if in 2 gears.. jack up rear, and then rotate engine backwards a hair while prying it back to neutral.
soundguy
Thanks to both of you who posted. I have had this problem before and had no problem getting it unstuck, but this time it has been really stuck.
Thanks so much and God Bless
Donnie D.
Ashdown, AR
   / Massey Ferguson 35 older Model #5
getting it off the ground will free the rear wheels and help unbind it.. same with spinning engine backwards 1/8"
good luck
   / Massey Ferguson 35 older Model #6
Thanks
Donnie D.
Arkansas
Sometimes you can take the fill plug off the top of the cover and pry the gears with a big screw driver.
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A52748)
GOODYEAR SET OF...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
