Massey Ferguson 2860 problems.
/ Massey Ferguson 2860 problems. #1
Kenss
2860 massey ferguson
Just under 150 hours on this machine almost all pulling a 12 foot bush hog in light mowing. It’s been back to the dealer several times, mostly for an A/C issue but now it’s losing power but only after 30 minutes of use. I thought it was heat related even though the gauge and light are good.
I pulled the thermostat, cleaned everything, treated the fuel, changed the fuel filter 3 times since it might catch any gunk and it just won’t run right.
The power drops so much that it can barely move even without the mower running.
Any tips for this frustrated owner to try since my dealer doesn’t return calls.
/ Massey Ferguson 2860 problems. #2
Well ... It basically needs three things to run, fuel, air, compression ... You seemed to rule out what I would have checked first, the fuel filter, but could there be another one in there? Or some blockage in the tank?
Air filter is next step I'd take, but really it shouldn't effect it after it runs a bit, either it's clogged or not ...
Mostly the same with compression ... Though if it gets hot it "could" be effected ... But in regards to compression ... That exhausted fuel/air has to go somewhere ... How have your regen's gone? Is it possible the emissions Diesel Particulate Filter (DPF) is clogged up?
/ Massey Ferguson 2860 problems. #3
Did you check the fuel cap vent to see if its plugged.
/ Massey Ferguson 2860 problems. #4
I sure hope "my dealer doesn't return my phone calls" is some kind of figure of speech meaning you do not get along well. Other wise that is absurd. The order of contact is Dealer > Regional Service Rep> AGCO Compliant Dept. With 150 hours I assume you bought it new? For heavens sake demand service and assist with solving this issue, do not accept NO for an answer and run it further up the chain as necessary.
What part of the country are you in? Within WVa, Maryland and PA I have never seen that kind of behavior from a dealer in 40 years and multiple brands -- Deere and MF.
BY the way: I am too lazy to chase/find the thread but there has been a guy on here for many months reporting a similar issue (not the dealer, the symptoms of losing power after using it around half hour to 45 minutes.) From his LONG thread and large number of discussions I think he has gone a bit further with investigations than you have but his tractor is not nearly as low hours as yours. The last I heard/recall some were blaming injectors for his problem and his dealer was baffled unable to solve it. In both cases -- his and yours -- the Regional Service Rep needs to be deeply involved until the issue is solved.
I did a lap around the field with the fuel cap removed to try the simple items first. I'll check if there is another fuel filter, and I'll push even harder on the dealer since i'm almost at the 5 year mark with the tractor. I also pulled and cleaned the air filter which was already clean. Could ejectors be an issue that creeps up after 30 minutes because I can hear the engine running with a tick but only after the 30 minute mark. It's regened twice since I bought it new.
/ Massey Ferguson 2860 problems. #6
Here is the thread you were referring to:
Massey Ferguson 1740M Hydro: LOSS OF POWER when hot!
That is exactly my issue that the 1740M is having, thanks for the link.
JWR I got on the phone with AGCO and my dealer snapped into shape. They went from arrogant “why are you bothering us” mentality to “let’s help you”!
We shall see A week from Thursday if they can find anything.
They said many of these model are having “fuel line routing issues” like pinch points.
/ Massey Ferguson 2860 problems. #8
That's good to hear, let us know what your dealer is able to find out.
/ Massey Ferguson 2860 problems. #9
This certainly sounds like a fuel starvation problem. This could be caused by a floater in the fuel tank that is partially blocking the fuel outlet or perhaps a weak electric fuel pump. The dealer should be able to figure this out.
/ Massey Ferguson 2860 problems. #10
I am not up to speed on Massey's but about 5 years a go a good friend of mine bought a 60 some odd Horse power Massey new and had the same problem you are having. Turns out he was getting algae in his tank and even after he treated the tank and changed the filters he was still having problems. He found there was a real fine screen where the fuel line came out of the tank. He replaced the screen a few times and it kept plugging so he took it out and tossed it. Has not had any problem since. He does change his fuel filters more often.
/ Massey Ferguson 2860 problems. #11
Blocked fuel line from a bug getting into the tank drove me crazy for a long time. I'll never understand why the manufacturers put a small line and/or a screen before the fuel filter. Just let the crap get to the filter to be removed.
The tech is coming today, but I didn't know there were more filters than the large canister that I already changed a few times. I hope that's it. I drained all the fuel, checked it out and treated fresh fuel after changing the fuel filter thrice.
The MF tech showed and found a kink in the fuel line. I’m surprised it’s single wall line that is easy to pinch. It ran good for 20 minutes and then got so weak it hardly moves even with the mower switched off. Saga continues.
I asked the tech and dealer if there are any other filters or screens that could be plugged and they said " There are no other filters besides the main fuel filter in my tractor type". The dealer came and picked up the tractor yesterday and the tech along with AGCO will hook it up to a dyno. I'm 2 weeks away from the end of the 5 year warranty. (y)
Dealer called and after running the tractor on the Dyno it replicated my issue. They are going to install new injectors. A known issue. :rolleyes:
I still don't have the tractor back. It's been at the dealer for a month, I call every day and the story I get is "We are swamped and have a 6 week back log, no loaners are available" Neighbors are calling asking why the whole farm looks like hell. Is an attorney needed to get this done?
2015 Chevrolet Express 2500 Cargo Van (A61568)
2015 Chevrolet...
Rogator RG1100 (A63118)
Rogator RG1100...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
8' DISC HARROW (A60430)
8' DISC HARROW...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
