Massey ferguson 1010 hydro , not moving I
   / Massey ferguson 1010 hydro , not moving I #1
RobSidGor
Recently purchased a 1987 mf1010 , seemed to work great , then it refused to move when the first snow came and tried the snowplow
First checked and topped up tranny/hyd fluid no change
Then thought maybe plugged or frozen moisture in filters ,I plan on ordering new ones
Upon further investigation I discovered the rear pto shaft us not turning when clutch is engaged
So my thought is that the clutch disc is worn and slipping , not turning pto or hydrostatic transmission
Does this sound plausible?
It also happened after overfilling and spilling diesel fuel down onto trans and engine , I wouldn't think it possible but could it have contaminated the clutch disc
Looking at having to split the tractor in the middle , hoping it's the clutch and not the hydrostatic transmission
Suggestions?
Thanks Rob
   / Massey ferguson 1010 hydro , not moving I #2
Spilling some fuel onto the clutch housing isn't likely to have much effect on clutch performance, particularly so in that short time frame. A slipping clutch is a good possibility, but what about pedal free play? Has that been checked (and adjusted) lately? Much more likely a problem right there could be involved.
  • Good Post
Reactions: JWR
Yup , I didn't really think it was from spillage , it can't he the first time tank was over filled lol
I'm going to get it moved into my tent/shed and over the xmas holidays and have a closer look at the adjustment and other things
Thanks Rob
   / Massey ferguson 1010 hydro , not moving I #4
Refused to move? Please elaborate/tell us more. Does the engine run? Any noises when you try to move it? Harry has good suggestions above. I have some Kubota B2150s that have a small swinging sheet metal toothed lever about 2 in long whose purpose is to hold the clutch just short of engaging while the engine is running (intended for some obscure maintenance activity I later found out.) I was worse than embarrassed and considering all sorts of drastic measures until I found that little clutch defeating devil. It amounted to a catch which made you think you had let out fully on the clutch but you really had not. No idea if other tractors have such a thing.
Thanks , the engine runs flawlessly but there is no engagement in clutch
I checked free play and even tried it with linkage removed to give it the maximum amount of clutch engagement
It doesn't turn the pto shaft or the hydrostatic transmission
I still don't have it inside under cover yet so haven't tried removing any sheet metal or acess covers but it really feels like the clutch is not engaging at all
   / Massey ferguson 1010 hydro , not moving I #6
Sounds as if a split is in the near future. Not a pleasant experience this time of year when done outdoors in snow country.
Yup I've resolved myself to that solution and have been looking at parts online
I have a 10x10tent/shed that I can put it in after moving some motorcycles , and will invest in a buddy heater
   / Massey ferguson 1010 hydro , not moving I #8
A heater will help, but what you really need is a floor. A couple sheets of plywood will work for a tractor that size. I've done that many times.
Yup definitely will be putting a sheet or two of plywood down , it's a crushed stone floor so need it for my floor jack to roll and axle stands from sinking
Have to move a couple of motorcycles to get it inside , my suzuki 1500cc intruder isn't going to move easily across the snow covered yard
Giyi Mini 40" Land Leveler (A57149)
Giyi Mini 40" Land...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
2024 8x22 Enclosed Trailer (A57453)
2024 8x22 Enclosed...
PREVIEW DATES AND TIMES (A57453)
PREVIEW DATES AND...
KUBOTA SVL75-3 SKID STEER (A52709)
KUBOTA SVL75-3...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
