massey 85 gas tank
   / massey 85 gas tank #1
dolmar man
massey ferguson 85
My massey 85's gas tank seems to have rust in it. it will plug the fuel line ahead of the gas bowl, to the point that i need to run the choke out more and more until it quits. i can then blow back in the tank and clear the blockage and it will be ok for a little while but will happen again. what can i do.
   / massey 85 gas tank #2
Remove the tank and clean. You can do this yourself by putting sharp edged stones in it, and turning repeatedly, then flush it out. Repeat as necessary... If you have a local radiator shop, most will clean/repair gas tanks.
Some use sealers, some not. If you keep the tank pretty well full after a good cleaning, and use clean fuel, it should be alright.
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
