Massey 5465 electrical help needed
/ Massey 5465 electrical help needed #1
Buck72
Massey Ferguson 5465
Hi all, I have a 2013 Massey Ferguson 5465 tractor which i recently purchased . The air conditioner control in the cab was damaged so i purchased a new one. When i removed the old control unit i found that some one had cut the 5 pin plug from the fan speed switch harness. My problem is i cant find a schematic which shows a 5 pin plug with 5 wires, i have been to my local Massey dealer they can only find a 4 pin and a 7 pin plug, does any one have a schematic or can take a photo of their fan switch plug. Any help would be much appreciated.
/ Massey 5465 electrical help needed #2
I do not have the tractor in question, so no pictures :eek:
Does your fan have 3 speeds?
I am guessing, if 3 speeds, one wire for each speed, a ground and 12v wire to make 5.
Sorry I can be of more help.
Hey thanks for info, fan has 4 speeds
/ Massey 5465 electrical help needed #4
Then I'll GUESS:
12v in to switch
Then wires 2-5 are out from switch for each speed, 1, 2, 3, & 4. Ground will be at the fan motor.
For a DC motor, I'll guess they used resistor(s) for speed control, except High, which would bypass the resistor(s).
Most likely a coil of resistance wire with a "tap" at 1/3 and 2/3.
Low 12v goes through all the resistance wire coils, then to fan
Next speed, goes into tap at 1/3 of the coils, so it goes through the remaining 2/3s of the coil, then to fan
Next higher speed goes into the tap at 2/3s of the coil, so it goes through the remaining 1/3 of the coil to fan.
High goes direct to the fan.
They may have used a separate resistor (of different values) in each of the lower speeds instead of a coil of resistance wire with taps.
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
