JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,805
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
The 2670 had the same engine as the 2660 but a little more HP. I think the 2670/80 had a little bit longer frame than the 2660 but too lazy to go fond where I saw that. The old spec sheets with wheelbase will tell you if you care.2012 HD Series 2670 Massey Ferguson - heavy equipment - by owner -...
Barn kept with only 1100 hours. Excellent condition. Heat/Air and Radio.westky.craigslist.org
Take a look at Sawtooth's excellent photos of his 2660 above -- the center picture (of the rear) clearly shows the 5 notches on the thick plate sandwiched to each side of the differential. That saves me sending at least one picture. I will still get you some pics w/r to the front end hydraulic motor driven things.
By the way it looks like the 3 remotes are common on cab models where only two are std with the rops models. And Sawtooth says the 12sp (instead of 8) tranny likely comes with the cabs too -- those two items are worthwhile for sure.
