Massey 240 hydraulic filter fit
   / Massey 240 hydraulic filter fit #1
Orchardist
Bretagne
Massey 240
Hi
I recently removed the hydraulic filter from the underside of the MF 240 transmission box. It was gunked up...causing slow lifting of the loader and linkage. Typical as we have just finished apple harvest.
I came to putting it back into position and wondered whether it had been installed correctly in the first place!
There is the filter and what appears to be an inner shroud that is free to move. The top of the filter has an inverted cone inner that goes in first against the pump, with open ended side of the filter facing the floor. I then put in place the small washer and spring, the nut and clip. The inner shroud then goes inside the filter but appears to be free moving.
Any ideas?
Thanks
Orchardist
   / Massey 240 hydraulic filter fit #2
G'day Orchardist.
Assemble this way.
first the large "o" ring then the shroud ,the one that fits on the OUTSIDE of the filter with the open end down,then the filter,then the Cone shaped piece with the cone fitting INSIDE the filter, then the small "O" ring that goes around the threaded part then a plain washer, then the spring then the nut then the clip then a new cover gasket and the cover.
happy days.
Hutch.
Thanks/ Merci!
I think the previous owner didnt install the filter correctly. Logic dictated the correct way up and everything is working really well thanks!
Now I am carting around my 600kg apple sacks without worries.
Have a nice evening!
Orchardist.
G'day Orchardist.
Assemble this way.
happy days.
Hutch.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2025 Swict 60in Bucket Skid Steer Attachment (A55787)
2025 Swict 60in...
JOHN DEERE 8345RT TWIN TRACK ROW CROP TRACTOR (A54756)
JOHN DEERE 8345RT...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A55788)
2015 Ram 3500 4x4...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
2014 Chevrolet Silverado (A55788)
2014 Chevrolet...
