Massey 240 hydraulic filter fit
   / Massey 240 hydraulic filter fit #1
Orchardist
Bretagne
Massey 240
Hi
I recently removed the hydraulic filter from the underside of the MF 240 transmission box. It was gunked up...causing slow lifting of the loader and linkage. Typical as we have just finished apple harvest.
I came to putting it back into position and wondered whether it had been installed correctly in the first place!
There is the filter and what appears to be an inner shroud that is free to move. The top of the filter has an inverted cone inner that goes in first against the pump, with open ended side of the filter facing the floor. I then put in place the small washer and spring, the nut and clip. The inner shroud then goes inside the filter but appears to be free moving.
Any ideas?
Thanks
Orchardist
   / Massey 240 hydraulic filter fit #2
G'day Orchardist.
Assemble this way.
first the large "o" ring then the shroud ,the one that fits on the OUTSIDE of the filter with the open end down,then the filter,then the Cone shaped piece with the cone fitting INSIDE the filter, then the small "O" ring that goes around the threaded part then a plain washer, then the spring then the nut then the clip then a new cover gasket and the cover.
happy days.
Hutch.
Thanks/ Merci!
I think the previous owner didnt install the filter correctly. Logic dictated the correct way up and everything is working really well thanks!
Now I am carting around my 600kg apple sacks without worries.
Have a nice evening!
Orchardist.
G'day Orchardist.
Assemble this way.
happy days.
Hutch.
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
KUBOTA B7500 TRACTOR (A54756)
KUBOTA B7500...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A55758)
STAR EV 36V...
