Orchardist
Hi
I recently removed the hydraulic filter from the underside of the MF 240 transmission box. It was gunked up...causing slow lifting of the loader and linkage. Typical as we have just finished apple harvest.
I came to putting it back into position and wondered whether it had been installed correctly in the first place!
There is the filter and what appears to be an inner shroud that is free to move. The top of the filter has an inverted cone inner that goes in first against the pump, with open ended side of the filter facing the floor. I then put in place the small washer and spring, the nut and clip. The inner shroud then goes inside the filter but appears to be free moving.
Any ideas?
Orchardist
Any ideas?
Orchardist
