Massey 231 front loader help
/ Massey 231 front loader help #1
Zeke1eod
Massey Ferguson 231, Long 360, Kubota B3200
I have a June 93 Massey 231 with a Massey 295 front loader and shaft driven external pump. It's always seemed weak/slow, now it will not lift at all. I checked fluid it was 1 gal low, and white ish milky possible water intrusion, which is odd always kept in dry, not crossing creeks etc. Looking at local dealers for filter screen and gasket. The draft and position levers are in up position and you can hear the pump engage, pto works and it will drive, if I tie loader joystick back and walk to front, pump is turning, I have service manual but hydraulic diagnostic info is weak, what should I look for, any valves on transmission or elsewhere? I have numerous pressure gauges up to 5k psi, where would I plumb gauge into check pressure and what psi should I use? Thanks in advance
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
